skywagon8a
SE Mass MA6
This is mine, a simple system. It operates on propane, does a nice job making it comfortable to work under. However, the rate of fuel consumption I thought was high. In 5 weeks of use it went through three 100 gallon tanks of propane. That I could understand, until the price of propane doubled. It cost over $1100 to heat the hanger for those 5 weeks. When I installed the heater the propane price was half of the cost to refill. So I had the propane removed and don't use it any more. That was 20 years ago, who knows what the cost would be today? There was likely a lot of heat loss into the upper section of the hangar and the door wasn't as tight as it ought to be even though it was clamped closed.Google suggested infrared- surprised you are the only one who has used it.
Anyone else with infrared experience?
