Results 1 to 10 of 10
Thread: High Temp Silicone tape/wrap
    WWhunter's Avatar
    Aug 2003
    1,637
    I've got a SCAT tube that runs very close to my exhaust. The exhaust is wrapped with an exhaust wrap that is abrasive to the SCAT tube and will wear a hole through it. The engine is tightly cowled and there really isn't anyplace else that I can run this tube. Generally I have used the high temp RTV to hold things in place. Has anyone used any type of high temperature silicone tape near the exhaust? Mainly want to wrap the SCAT tube for added protection and to hold it out of the way. I was thinking about something like this: Permatex 82112 Self-fusing Silicone Tape
    Any recommendations of what I can use? Thanks!!
    Don't take life too seriously ... no one gets out alive!
    May 2014
    957
    If there’s room, and it’s practical, you may also consider clamping a metal heat shield to exhaust.
    even a 1/2” air gap will provide big drop in temps. Also act as a stand-off for scat tube.
    maybe combination of both - heat shield and hi temp wrap?
    7,981
    Make a standoff with a glob of RTV. Put a shim in place to hold the spacing while the RTV cures. Maybe make a bundle of exhaust wrap to make the spacer.
    4,866
    It's going to be a trial and error thing to see what works best, but I'd recommend starting with what Stewart said. Glue a metal shim between the two and run it for a while. And use high temp RTV instead of the regular.
    7,981
    I have a place where my exhaust contacts exhaust. I bought some exhaust pipe wrap from O’Reilly’s and folded it into a 4 layer packet with high temp RTV to hold it together. Left it in a vice grip to let the RTV cure. Pushed it into place. So far, so good.
    22,362
    I have wrapped a piece of silicone baffle material around SCAT tube before but wasn't in direct coct with the exhaust. Might need a little experimentation.
    4,243
    Aircraft Spruce and others offer a variety of heat shielding material. Flexible metal duct hose is also available. Isn't that what was used before SCAT was invented?
    Likes cubpilot2 liked this post
    Dec 2009
    Michigan
    184
    Quote Originally Posted by Oliver View Post
    https://antisplataero.com/products/heat-shield-system
    7,981
    I used some sleeve type tube insulation by this company. This product looks useful for the problem described.
    https://www.cabletiesandmore.com/ins...iABEgIt1PD_BwE
    WWhunter's Avatar
    Aug 2003
    1,637
    Thank everyone for the great help and advice. I got some high temp RTV and I think I have some baffling material. will try that first. I'll tie the scat tubing in a position that I want it and then goop it up good. Hopefully it'll be a little warmer out today to allow me to get it done. Had to get a 3rd function hydraulic installed on my tractor and the high yesterday was around 5 degrees. -14 windchill earlier and no heat in my shop. Brrr.
  1. PA-12 High oil temp
    By txfirefighter628 in forum Super Cub Sick Bay
    Last Post: 08-03-2015, 08:46 PM
  2. Oil Temp High
    By nesincg in forum Retracing Flight of Passage
    Last Post: 07-01-2014, 09:28 AM
  3. oil temp high
    By swoeric in forum Super Cub Sick Bay
    Last Post: 10-05-2011, 08:50 PM
  4. High oil temp
    By Dennis Blankenbaker in forum Super Cub Sick Bay
    Last Post: 06-05-2005, 05:24 PM
