Results 1 to 19 of 19
Thread: Too funny not to share
    jrussl's Avatar
    Jul 2005
    Madison, WI
    827
    A friend posted this question today. I found it too damn funny not to share. Compliments of Ethan B.
    If the amount of oil on its outside equals the amount of oil on its inside, then the oil will leak in instead of out, right?
    Apr 2014
    25
    Well... technically this is incorrect. If the amount outside equals the amount inside then there should be no transfer so you should theoretically have no leak.
    Hmmm. Might be worth a try.
    Quote Originally Posted by jrussl View Post
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,184
    Quote Originally Posted by tzfred View Post
    If you want technical rather than an attempt at humour - the transfer direction and rate do not depend on the quantity/amount inside or outside. What matters is the pressure differential between "outside" and "inside".
    Thanks rjhamann thanked for this post
    Likes Troy Hamon, Geewhiz, BC12D-4-85 liked this post
    Apr 2014
    25
    Ouch. Well it was an "attempt" at humor. I thought the original post was funny and thought I would add to the conversation obviously related to tracking and fixing leaks on our trusty engines. Just thought the idea that once you spread enough oil on the outside the leak might stop was funny . But I guess it was just me.
    Having said that I was led to understand that Bernoulli, using a few very creative boundary conditions simplifies the potential flow equation to give us a simple solution to incompressible flow (most everyday liquid transfers). The leak in fact is related to the sum of the head, the velocity squared, and the pressure on either side of the plane of interest. But thanks for clarifying. I'll step back from this thread now. My apologies to any other readers for taking a light hearted friendly giggle and making it serious but...
    Likes cubscout, mam90, Hardtailjohn, BC12D-4-85 liked this post
    4,849
    Ranks right up there with 'is the sea level higher in Alaska?'
    Likes jrussl, akavidflyer liked this post
    cubflier's Avatar
    Nov 2003
    1,447
    That's a deep subject.
    Jerry
    Dec 2018
    Rangely, Co
    107
    I liked it! But I had already run an experiment to check the validity. For years. So I had inside knowledge
    Likes cubscout, jrussl liked this post
    Sep 2002
    971
    It was great. So was your response.
    RVBottomly's Avatar
    Sep 2017
    1,390
    Reminds me of my childhood best friend with a homemade truck camper. It had a flat front and gas mileage was around 10 mpg. We rigged up a piece of plywood and braces to direct the air flow over the camper, and suddenly got around 15 mpg.
    So, he said, "let's make it bigger. Pretty soon we will be making gas!"
    Why not?
    Likes jrussl liked this post
    Sep 2002
    971
    Or the 747 that started losing engines over the Atlantic.. every time they lost an engine the Captain would announce that they could continue, but would be progressively later and later to their destination. So they lose the third engine and the Captain assures them they could continue on one, but would now be 3 hours late. A passenger turns to his buddy and says “if we lose that last engine, we’ll be up here all day”…
    4,210
    Always there's some smart jazz answer> https://oceanservice.noaa.gov/facts/globalsl.html
    Oil leaks are a math function of suck and blow pressure. So, it depends on which side of that you are. In my opinion.
    Likes MartyC, jrussl liked this post
    RVBottomly's Avatar
    Sep 2017
    1,390
    I was trying to keep my mouth shut on that, but I also think gravity is a little stronger up north, too.
    4,210
    Yup! https://en.wikipedia.org/wiki/File:G..._animation.gif Instead of 5'9" I'd be taller in the Blue areas.
    12,691
    Does this mean ships need more floatation to cross the north Atlantic than the Pacific?
    Likes jrussl, mixer liked this post
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    335
    sea level stays the same, the shoreline just raises and falls 30' every 6 hrs.
    Likes cubscout liked this post
    4,210
    Depends. Floatation is determined by surface water density (a function of temperature and salinity) which can be higher near the colder Polar regions. Any nearshore layer of fresh water from rivers or melting glaciers can affect that some. It's a loaded float aircraft in seawater vs fresh, thing.
    4,177
    , multiplied by the local acceleration of gravity.
    Thanks chuckwagon thanked for this post
    Likes BC12D-4-85, chuckwagon liked this post
    4,210
    Oil tank leakage to floating ships at sea....quite a thread drift. Winter in the Arctic causes this.
    Here's more on the mystery of floatation. Note a ways down in the article the load lines or Plimsoll marks on ship sides and how they vary under different environmental conditions. Gordon's gravity noted previously affects floated stability....we have lost top heavy crab fishing vessels because of that issue.
    May 2020
    13
    So which is oilier, Kansas, Nebraska, or Texas? I guess it depends on which sucks or blows and when. Sorry, old Kansas joke about why it is so windy in the state.
  1. too cool not to share
    By Snert in forum Cafe Supercub
    Last Post: 01-06-2007, 07:11 AM
  2. Share the Fun: First Cub Lesson
    By JP in forum Cafe Supercub
    Last Post: 03-31-2004, 04:28 PM
