Hello, I am helping a friend that just bought a well used 185 over here in Sweden.
He said that two of the cylinders had bad compression. I had a look with the borescope, and found that the exhaust valves on these two cylinders has heat damage. Parts of the valvefaces is green, indicating exhaust gas leak and subsequent overheating. The engine has around 1100 hrs since factory reman done in 1995. New cylinders was installed. I wonder why the valves of these two cylinders has started to leak, and not all of them. I found something that could be a leading clue. The rocker arm thrust washers has eaten into the metal of the rocker bosses on the thrust side. But the wear step is not the same depth around the circumference. It is very deep on one side, and almost no wear on the other side. Could the hole for the rocker shaft be misaligned from the factory? If so, this could be the cause for the valve to have been slightly “sideloaded” and now after 1100 hours the valve guide is enough worn so that the valve does not seat properly? What do you think about my theory?
I did try to find any wear limits for the rocker shaft bosses but have not found anything yet. We are planning on honing and replace/reface the valves on all cylinders, but I need to find out if they are serviceable before starting any work on them. Any inputs is appreciated.
(I am a A&P, but with limited experience on the IO-520)
