Page 1 of 2 12 LastLast
Results 1 to 40 of 52
Thread: Fairleads during cable replacement
    cubdrvr's Avatar
    Jan 2002
    1,459
    Any tips on installing the snap ring of the rear rudder fairleads? I have just the one inspection panel on the left side other than the jackscrew panels and the far aft rectangular panel.
    Looks like I might have to add another inspection hole so I can use both hands. Thoughts?
    4,177
    Maybe modify some internal snap ring pliars with little dimples to capture the spring while spreading it???
    4,207
    Would a safety wire loop work?
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    406
    Leave it in, mark the cable for the proper length, run the cable and swedge the thimble at the tail last.
    PA-12 N418BS
    22,349
    Glue an inspection ring on the belly by the fairlead.
    cubdrvr's Avatar
    Jan 2002
    1,459
    We already discussed that Boss............I'm thinking remote robotics.........not ready to give up yet
    Grant's Avatar
    At Work.....
    2,076
    Put the snapring over one of the fairlead pieces centering the snapring with the open part toward the other half of the fairlead . Then slide the other half in and work the snapring as you push the fairlead into place. Its easier to show than explain.... It can be done with one hand.
    Likes Gordon Misch, BC12D-4-85, tedwaltman1 liked this post
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,459
    What Grant said does work, but if access and dexterity do not allow..
    Cut a short piece of tubing that fits close over the back end of the fairlead. Cut a slot in it so it can be slid over the cable. Stretch the ring over the tube, put the tube over the cable, over the fairlead end, and slid the ring off the tube onto the fairlead.
    Likes Gordon Misch, BC12D-4-85, jrussl liked this post
    4,177
    You guys are clever. Love it!
    Charlie Longley's Avatar
    Jan 2008
    Anchorage, AK
    940
    Are you serious?
    4,207
    Are you serious?
    Actually yes. I've seen several two piece plastic fairleads snapped into the round metal frame and held together by sufficient safety wire wrapped in the plastic ring groove to prevent movement and loss. Also seen with wooden fairleads years ago on Piper lift struts.
    Edit: See #10. The standard ring is best, but sometimes access is limited. https://www.flywithspa.com/docs/pbm/...er-cables.html
    22,349
    Easy to glue and cut an inspection ring.
    Those fairleads just outboard of the fuel tank can be a bear. I have used .041" safety wire instead of the snap ring.
    Likes bob turner, ak49flyer, tedwaltman1 liked this post
    Jan 2008
    Anchorage, AK
    940
    Learn something new everyday.
    cubdrvr's Avatar
    Jan 2002
    1,459
    Thanks guys..........I'm stubborn enuf to try anything before I cut a hole in my fabric, although it might come to that.
    Formandfunction's Avatar
    May 2022
    65
    I misplaced a nice set of snap ring pliers that had a dimple for holding those rings. Actually had a conversation with snap on last week about a replacement. Sticker shock might make you cut a hole in your plane though.
    4,207
    Why not use a proper sized snap ring with holes for the pliers?
    4,839
    Different style of snap ring on the fairleads. No holes in them.
    12,684
    They would work though.
    Dec 2009
    Michigan
    184
    Snap Rings with holes installed and removed with pliers is what I use, Gary.
    4,207
    I guess if the regular snap rings are a PIA why not use what works easier? It might be helpful to note a part number for replacement. Maybe that's why some A&P's up here have used safety wire instead.
    12,684
    Every mechanic has a "fits all" roll of safety wire on his work bench.
    cubdrvr's Avatar
    Jan 2002
    1,459
    That's the route I'm going.......found the exact size. One down.......one to go.
    Likes BC12D-4-85, AkPA/18 liked this post
    4,839
    This is what the book calls for.
Name:	Screenshot 2022-11-14 at 13-17-05 U40081-000 UNIVAIR FAIRLEAD SNAP RING - FITS PIPER.png
    4,207
    5/8" I.D.?
    May 2014
    957
    Are you replacing fairlead due to wear?
    or to thread new cable assy?
    Suggested earlier was to make new cables in place.
    sounds like you’re beyond that phase though.
    It may sound intimidating but saves a lot of work and expense.
    there was a thread that discussed the process s few years back.
    I just made up a complete fuselage set last week, I’ll need to do wings as well soon and happy to rehash the process if a search dosnt turn it up.
    cubdrvr's Avatar
    Jan 2002
    1,459
    I made my own at rebuild. Should have done it this time also......but bought Univair set. PITA !
    But......I will have all the old cable ends should anyone need them.
    22,349
    I told you to glue grommets and cut holes. Just think about all the pheasants you missed by being stubborn.
    Likes mixer, RaisedByWolves, 40m, bfd777 liked this post
    cubdrvr's Avatar
    Jan 2002
    1,459
    Shut up
    Likes DENNY, RaisedByWolves liked this post
    8,085
    Seems to me if you are careful, gluing a ring on wouldn't even require touch-up paint.
    4,207
    Stewart's method glue is great for this. I have several on my Taylorcraft added post recover. Clean surface, apply glue and ring with fabric overlay. Wipe off excess along edges with wet cloth before it drys. All still attached 6 yrs later on plane parked outside +80's to -50's.
    22,349
    Quote Originally Posted by cubdrvr View Post
    Shut up
    Tom Ford and I were gonna make this sign and hang it in our hangars. The worst are the ones that want to argue about your answer.
    4,890
    Steve’s too nice. I’ve found it’s easier to keep your mouth shut and watch. The problem when your a kid, you can’t possibly know anything.
    12,684
    I too have had a lot of people like that at my airport.
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    433
    There is a ring tool, KD-2354, with flat ends that work well for installing the rings. Not so much for taking them off.
    GearWrench 2534 E-Ring Lock-Ring Pliers
    Likes AkPA/18 liked this post
    cubdrvr's Avatar
    Jan 2002
    1,459
    All control cables I have installed in the past have been at recover. This is the first time installing with cover on the bird. So my advice, even though not solicited, is to never, never buy a pre-made set to install on a covered cub.
    Every fairlead and pully needs to come apart. Pulling a cable with one bare end would be a simple process. Never too old to learn the hard way.........and no pheasants in the freezer yet.
    Likes AkPA/18, jrussl, Steve Pierce liked this post
  36. #36
    4,890
    Sense your an old pro now, want to swing by and help with these rudder cables? I already replaced the elevator. Not during recover.
  37. #37
    Jan 2021
    Nevada
    99
    And that's a bad thing how? I used to have a girlfriend who would read a particular film reviewer in the paper. If they hated the movie it was going to be good. Worked every time. Just because someone doesn't want to do something your way doesn't mean they're unsafe or even disrespectful. The person who fails to endorse your advice is not belittling it. Perhaps they're even looking for something they can eventually join you in, but haven't gotten there yet. The mere act of asking indicates some level of respect, so "Accentuate the Positive" and enjoy that - even if it's not what you'd hoped for.
  38. #38
    4,890
    Quote Originally Posted by RedOwlAirfield View Post
    Save the time and don't ask. It gets old when 10 people or more a day ask you questions
    Likes mixer liked this post
  39. #39
    4,839
    You've missed the point. The guys from the sign don't really want the advice, they want you to affirm that THEIR way is the best.
    And, by the way, if you see Dolf Lundgren in the cast, don't bother with the movie.
    Likes Bill.Brine, Brandsman, tedwaltman1 liked this post
  40. #40
    4,177
    I definitely get that, but also it depends on whether they're freeloaders or good customers. I think Redowl is right in the point he makes, but I also agree that it's a different point than you had in mind. Asking for advice then insisting on receiving a particular answer is not honest asking.
  1. PA-12 underwing fuel "gauges" replacement parts/replacement in general
    By Philly5G in forum Piper: PA-12 Super Cruiser
    Last Post: 08-30-2020, 02:20 PM
  2. 185 throttle cable replacement
    By Tom3holer in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 07-29-2016, 11:47 AM
  3. Replies: 7
    Last Post: 10-27-2010, 10:31 AM
  4. Small Fairleads on Struts
    By behindpropellers in forum Super Cub Sick Bay
    Last Post: 11-12-2007, 08:29 PM
