I think they are all 4x1/4, but the ones that go in the spar are "B". Think of that B as "blunt end."
Piper, way back when, had really shallow slotted head PK screws. If you can find them, your fabric bumps will be less obvious.
If you are starting with a new spar, I recommend pre-tapping the holes. I used a 1/4x3/8, gripped in small Visegrips. Tap ten holes, then get a new screw. They are hardened, and if they break off in the spar you get to re-locate the hole.
