Originally Posted by
S2D
First off forget the word paint. If your plane is original like it looks, you have dope on it .
Nitrate dope then clear dope then silver dope then white dope.
When you start rubbing that acetone in,bit will all mix together. Rub it til the edges are feathered. You really can't screw it up if it's dope.
Now someone might have gotten lazy and sprayed some enamel paint on some of those repairs.
They will be a little harder to get that enamel off before the dope starts blending together.
Once you get an area feathered, you start building it up with dope. Clear, silver then white. Or skip the clear. Skip the nitrate too.
On the bigger areas that have started to peel, go ahead and get rid of the loose piece, feather the edges and build back up with dope, not paint.
Lot of elbow grease but not real expensive to buy some time before you have to recover.
