Page 1 of 2 12 LastLast
Results 1 to 40 of 73
Thread: Difference between CC & Dakota headerless designs? Exp PA18 Fuel system decisions
    Aug 2015
    AK, ME - what time of year is it?
    811
    Does anyone have the install drawings for the CC and the Dakota headerless fuel system (PA1 they can share?
    Any commentary on differences between them is welcomed!
    Am currently planning fuel system for Legend PA18 with Atlee 30.5g tanks, and there is musing at the Legend factory that a crossover tube may not be needed. There is also a suggestion to just go with simple on-off valves for each tank instead of a single L-R-Both-Off.
    I am of the thinking that if a vented cap gets clogged, a tank could be deformed/collapse from the fuel/air draw. Always thought the crossover tube, even with its potential sidehill parking issues of draining from one tank to another, was a good idea to equalize the pressure.
    J
    3,073
    If you wanted the crossover vent just put outboard vent ports like Skywagon mentioned then whatever valve you want. Best of both worlds. DENNY
    3,073
    On another note I know the older Atlee tanks had a outboard vent that came out the bottom of the tank. Does yours still have that? DENNY
    7,952
    My Cub’s fuel vents are Cessna style.
    If running on Both is it possible to collapse a tank if one vent is blocked? I wouldn’t think so, and a guy should recognize one tank is emptying before he runs out on the one tank.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,530
    Where does the vent tube exit your tank? I'm not familiar with the Cessna set up. How do you prevent overflow out the vent tube?
    Marty57
    N367PS
    www.marty2plus2.com
    7,952
    The vent is high on the outboard side. Like Cessna, it uses a one-way check valve so fuel doesn’t find a way out.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,530
    Got it, that's easy to add into a fuel system. Thanks
    Marty57
    N367PS
    www.marty2plus2.com
    4,177
    I wonder about the check valve when the fuel tank is heated and everything tries to expand and vapor pressure increases. Does it maybe have a tiny hole for that purpose?
    7,952
    Standard vented caps. They cover the expansion problem while the under-wing vents allow higher flow rates for bigger engines.
    Likes marcusofcotton liked this post
    4,177
    Ah, I see. Also provides vent redundancy. Thanks.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,530
    Something like this? Opens at 1.5 psi according to the specs.
    Marty57
    N367PS
    www.marty2plus2.com
    12,684
    Those Cessna valves are notorious leakers when the tanks are full. It could just be because of their flapper design? Also the Cessna tanks have a cross vent tube which is open inside the tanks on the outboard ends. So when the tanks are full with one wing low, the fuel does flow across ship and overboard until the level goes down a bit.
    Did you ever wonder how the fuel tanks are vented in the long wings on an airliner? The vent is connected to the tank at the outboard end of the tank, the vent tube then goes all the way across ship to the other wing tip where the vent exits under the wing. No cross flow at any wing angle. There is also a small collector tank at the outlet in case there is any overflow.
    If stewart's vent was connected to the top forward inboard corner of the tank with the vent mounted where it is, he wouldn't need the check valve. Fuel being as viscous as it is can work it's way through some of the best valves.
    22,349
    Quote Originally Posted by JohnnyR View Post
    J
    CC and DC headerless fuel systems are identical in respect to plumbing. Only difference is the DC system calls out their fuel valve and gascolator.
    Dec 2016
    Canyon, tx
    1,082
    Is there much difference between DC’s gascolator and Steve’s gascolator?
    Scott A's Avatar
    May 2007
    Park City, UT
    40
    I'm sure it has been mentioned somewhere already - for the simple inboard cross vent line a shutoff valve in the crossover line can be used to stop the side hill parking issue. And if you forget it in the closed position not really a big deal 99% of the time.
    7,952
    I’ve never had a drip from my fuel vents in either airplane. The Cessna usually doesn’t get the tanks filled but the Cub does.
    Fuel cross-feed in my planes occurs from the fuel valve being on both. Easy to prevent but I’ve never bothered with it on the average slopes I park on. My valves stay on both unless shut off for maintenance.
    22,349
    The DC gascolator has the capacity for larger tanks than the standard Steve's.
    Thanks KevinJ thanked for this post
    7,952
    Johnny, what's your target fuel flow? Mine was 30gph and I met that with a little extra. Flow is dependent on venting. Don't short yourself.
    DJ's Avatar
    Jan 2009
    Bolivia
    484
    There is a pin hole in the flapper valve. The line is supposed to rise after exiting the tank to reduce dripping.
    Cessna vented caps only let air in.
    Aug 2015
    811
    Your point is well taken!
    I'll check with Aerosport. It's their IO-375 but with 7.8:1 pistons (for burning mogas/autofuel), so not likely to produce more than 190hp.
    Fuel Flow Calculations for Horsepower – performancedevelopments.com
    White City, Oregon
    993
    Both have the same 3oz bowl sediment capacity Steve. The only thing DC did different is the bowl retention with the screw..
    FAA regulations is 1 fluid oz per 20 gallon main tank size. 3 fluid oz is good for up to 60 gallon main take capacity.
    I have an optional 4 oz bowl for even larger fuel tanks up to 80 gallons.
    Brian.
    Thanks cubscout thanked for this post
    Superbill's Avatar
    Dec 2021
    Lostine Oregon
    27
    I've got a header less system with no crossover or both valve. I had a vent failure cause fuel starvation. Fortunately it happened on landing. The tank was collapsed to the point that I couldn't get a grip on the cap. I pushed up the drain to let air in, got a new cap, and so far so good. It was a good lesson!
    Thanks marcusofcotton thanked for this post
    Likes DENNY, Scott A liked this post
    Nov 2021
    36
    There is a reason for the balance vent tube between tanks and the forward facing Fuel caps that pressurize the tank.
    There is good reasoning for all these features. I installed it because these features make sense to me.
    Everyone always seems to have a better Idea but these ones are proven.
    Likes mam90, Scott A liked this post
    22,349
    Quote Originally Posted by Steve's Aircraft (Brian) View Post
    Brian.
    I was thinking DC told me they made their bowl with more capacity, maybe it was more capacity than the original. I remember working on a Super Cub with Atlee tanks and two gascolators and replacing it with your larger capacity bowl. It is easier to get the cotter pin retaining the bowl on your gascolator than the screw on the Dakota Cub gascolator.
    Likes Litecub liked this post
    White City, Oregon
    993
    Original Piper is 2oz. We went with 3oz because when we were developing the STC we wanted to match Husky bowl size and have it on the first AML.
    Brian.
    Thanks Steve Pierce, soyAnarchisto, jrussl thanked for this post
    Likes pfm liked this post
    Nov 2021
    36
    I have not been able to get a hold of DC to see if steves gascolator will be acceptable under their STC
    I know CC stc will not accept the DC fuel valve.
    The Dilema was we have the DC fuel valve with the Steves larger Gascolator and the CC STC
    Unfortunately I did not have the STC to read before I bought it. At least the 24 gallon tanks are accepted under the CC stc
    Thanks cubby thanked for this post
    22,349
    Quote Originally Posted by Dog View Post
    I have installed DC fuel valve in a Cub Crafters fuel system. The CC fuel system is installed under one STC and the DC valve is installed under another STC. It is up to the installer to verify that one STC does not negatively impact the other. Dakota Cub developed their own headerless fuel system STC to sell their fuel valve and gascolator. They give you the STC when you buy the parts. The STC was developed out of the certified Super 18. Mark (the owner) is a machinist and didn't want he type certified airplane to be dependant on a vendor gascolator when he could build his own.
    Likes stewartb, Eferr liked this post
    Aug 2015
    811
    Some questions on fuel system design:
    I'm curious - How would a "Both" valve reliably ensure fuel flow from a tank with a blocked forward facing pressure cap if there was no crossover tube or other secondary venting provided for the tank?
    Couldn't the system be forced to only pull air off the "unblocked" empty tank on the other side because pulling from the "blocked" tank after sufficient vacuum was formed would require air to travel back through fuel in the feed lines of the blocked tank? See the areas marked with red arrows for sections that could completely cut off flow with an airlock.
    Seems like in order to safely capitalize on the benefits of the L/R/Both/Off valve, there needs to be a secondary vent system. Ram air fuel caps can suffer from icing, bug invasion, etc., as can any venting, but to rely on just one source of equalization?
Name:	CC-Dakota headerless tube routing.jpeg
    Thanks AKlindy thanked for this post
    12,684
    You have just described several good reasons for installing a cross vent line. If there is any potential for vent blockage in your use of the plane, then absolutely install a cross vent. Make certain you connect it to the outboard ends of the tanks to ensure only air cross feeds.
    Nov 2021
    36
    The main reason for the cross vent tube is that if one tank runs empty and you do not have the cross vent tube the air pressure from the empty tank will go down the fuel line and push against the remaining fuel in the opposite tank - reducing or even stoping the flow. The cross vent will allow the top and bottom pressure to equal out to allow the remaining fuel to flow to the carb.
    4,177
    Unless the full tank's vent is blocked, how could the air pressure from the empty tank exceed the air + fuel pressure (gravity head) from the full tank?
    Nov 2021
    36
    Thats right air pressure would equal out and all you have is gravity without air pressure to help fuel flow (that may or may not be enough with this system), now if the vent is clogged -- the most likely scenario when you have a fuel imbalance ( Because we all fly perfectly with the ball centred at all times ) you will have a fuel starvation problem.
    Likes mixer liked this post
    7,952
    Snorkel caps are a "fix" to increase fuel flow from a system that wasn't designed for that much flow. For a new build, why not design the venting to provide the required flow?
    4,839
    How would the pressure change? I.e., if there was 1/2 psi air, pushing fuel out of both tanks, down to the selector valve (set on 'both' for this scenario), if one tank runs dry, the 1/2 psi air pressure in the line would remain unchanged. And if 1/2 psi air pressure was still pushing fuel out of the other tank, how would the flow of fuel be disrupted?
    When no snorkels are installed, the pressure on each line is simply head pressure from the weight of the fuel. 'Left', Right', or 'Both', with or without cross venting, they seem to work fine under normal circumstances.
    22,349
    Dakota Cub used 1/2" lines to provide required fuel flow at those crazy angles of attack with the slotted wings.
    Aug 2015
    811
    Are folks with doors on both sides running the single 4-way valve? How are the lines routed?
    Dakota and CC install diagrams seem to run the lines through where my left hand door is located.
    J
    12,684
    From the two rear outlets move aft behind the baggage then down and forward under the floorboards, then up to the valve. The two front outlets run down the front door posts to the valve. The right forward, down the door post across under the instrument panel down to the valve. Quick drains at the low points.
    Thanks JohnnyR thanked for this post
    4,177
    Yes, what Sky said is how we've done the Exp I'm working on. One exception, the aft ports run down on the aft side of the rear door posts.
    I believe it's important to have drains at each low point and vents to tank tops at each high point.
    12,684
    There should be no high points which can become an air block. To add to the above, the aft lines are clamped to the diagonal tube which goes down from the wing fitting to the next station aft.
    An air bubble in the tube can restrict or stop a low head pressure gravity flow.
    Aug 2015
    811
    Even though we have the 4-way Dakota valve on hand, at this point planning to go with two simple on/off valves and a crossover vent from outboard ends of tank. Pic not my plane but shows valving each side. Front and rear pickups from Atlee 30.5G tanks. Lowest points from each tank to drains rear of cargo pod. When all was considered, it seems this is best way to preserve KISS principle and future serviceability of fuel system.
    Differing opinions are welcomed, as always.
  1. Headerless Fuel System
    By Steve Pierce in forum Modifications
    Last Post: 05-11-2006, 01:25 AM
  2. STC # for CC headerless fuel system?
    By behindpropellers in forum Modifications
    Last Post: 11-05-2004, 02:58 PM
  3. Headerless Fuel System
    By murph in forum Modifications
    Last Post: 02-14-2003, 01:59 PM
