Results 1 to 13 of 13
Thread: Tailwheel Assembly
    Jan 2017
    PNW
    209
    Tailwheel Assembly
    Looking for recommendations on tailwheel assemblies for my supercub project. I purchased the Acme Stinger tail suspension. I currently have the Scott/ABW 3200 baby Bushwheel on my Maule. Iím getting irritated with that because the thrust plate has three pins that are press fit. The pins fall out of the plate. Iíve tried a number of fixes but nothing lasts. I called Airframes AK and was told it was a common problem which they were not inclined to fix because it would require FAA approval. The part is $76 and only seems to last 50 to 100 hours.
    Iím experimental so I donít need certified stuff but do want good stuff. Are there any tried and true field tested alternatives to the 3200? (Hopefully without the frequent parts failure built in)
    Thanks.
    stewartb's Avatar
    Wolf Lake, AK
    7,780
    Matco. I happen to have a new unit on my shelf if your interested. http://www.matcomfg.com/TAILWHEELDUA...v-3730-70.html
    Jan 2017
    PNW
    209
    Stewart,
    Do you have a Matco tailwheel on your cub. If so, has it survived long? Have you had a 3200 in the past?
    stewartb's Avatar
    Wolf Lake, AK
    7,780
    I used an ABW assembly. I did so because Airframes and Dan Dufalt were good enough to give me a credit for returning a T3 so I had money to spend. Most of the exp guys I know use the Matco and like it. Mine is surplus.
    8,024
    Did you know that there is no TSO for tailwheels? CAR 4a makes some kind of statement about tailwheels - maybe CAR 3 says the same thing.
    22,234
    I on occasion find those pins broken but not on tailwheels I have been maintaining. Not sure wat I am doing different but I do not see that very often at all.
    Likes hotrod180, wireweinie liked this post
    tedwaltman1's Avatar
    Jul 2011
    Delta, CO
    641
    Suggest you check for play in all the primary bolts of the Acme Stinger tail suspension. Mine has a lot of slop right out of the box. Also, suggest when assembling the Acme Stinger tail suspension, you torque to published AN specs, rather than to the torques listed in the Acme manual. Acme recommended torque values are significantly higher than recommended for AN hardware.
    11,399
    Quote Originally Posted by tedwaltman1 View Post
    Suggest you check for play in all the primary bolts of the [COLOR=#333333]Acme Stinger tail suspension. Mine has a lot of slop right out of the box. Acme recommended torque values are significantly higher than recommended for AN hardware
    Trying to remove the slop?
    Jul 2011
    Delta, CO
    641
    To reduce/eliminate bolt-to-oversized hole slop, Acme told me to —way— over tighten bolts. As in greater than 50% over-torqued. I did not do that. I can, and probably should, post pictures and video. Maybe in a separate thread later…
    Thanks frequent_flyer thanked for this post
    2,992
    If the pins are getting sloppy I just hold the pin and peen the other side above the plate to tighten them. Watch steves video and make sure all the parts are working correctly. Doing tail first landings with a tail heavy plane will be hard on any tailwheel so I would opt for a wheel landing if possible. DENNY
    Likes stid2677 liked this post
    Jan 2017
    PNW
    209
    Denny,
    I’ve tried peening. I’ve also brazed them and resurfaced the plate. That held up the longest but still failed. I can’t tell that they have failed until I pull it apart at annual. Since I can’t tell they failed I guess I don’t know what their function is.
    Grant's Avatar
    At Work.....
    2,059
    ... but I do not see that very often at all.
    Me either. Lots of loose attach bolts...but not many broken pins.
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,051
    Quote Originally Posted by Mr. Ed View Post
    I had assumed those pins provide the rotational coupling between the fork and the thrust plate. If that is correct then any time the tail wheel shimmies the pins are subjected to a rapidly reversing side load. If the pins fail then doesn't the friction damper become ineffective?
    If that analysis is correct then pin failure would be expected to be more common on tail wheeels that shimmy often. I think you said this was a BBW which appears to be more likely to shimmy than the standard wheel and fork.
    (I have never completely dismantled my tailwheel so happy to be corrected by those who know the assembly better than I do)
  1. Where to purchase a C185F tailwheel assembly?
    By trkling in forum Cafe Supercub
    Last Post: 05-30-2012, 11:53 PM
  2. Single Bolt Tailwheel Assembly Problems
    By eski in forum Cafe Supercub
    Last Post: 11-05-2008, 05:52 PM
