Results 1 to 20 of 20
Thread: Oil On My Belly
    Nov 2015
    103
    Oil On My Belly
    Experimental J3, Rolls Royce Engine, for a mental picture, the engine is very similar to a Continental C90. Oil from the breather tube, not a lot but a bit and considering a crank case vacuum and oil separator from Anti Splat Aero.
    https://antisplataero.com/products/t...-oil-separator
    and
    https://antisplataero.com/products/c...m-kit-complete
    Does anybody have any experience with these or am I just adding more weight and complexity?
    Opinions?
    Zach
    SJ's Avatar
    Jan 2002
    Northwest Arkansas
    15,962
    My experience is they are not worth the metal they are made with, but others may disagree...
    Likes bob turner, mixer liked this post
    Jan 2016
    102
    I would try and find the issue of the excessive blow by first, not sure with the C90’s but there is a modification to the breather line elbow on the crank case, it consists of brazing a three inch long tube with a slight angle cut. Seems to help on the other small Continentals from throwing oil out the breather, even with good piston rings.
    Likes rjhamann liked this post
    11,399
    Quote Originally Posted by Sikorsky View Post
    and
    Opinions?
    Zach
    What oil level are you running
    Likes DENNY liked this post
    Nov 2015
    103
    I’m having trouble picturing the 3” long tube with an angle cut. Actually I can picture it but don’t know how shortening the tube will help. I have a 2-3 foot line going to the vent and then venting out the bottom of the cowl. The build was extensive with new everything with proper brake in procedures in 50-60 degree weather.
    Nov 2015
    103
    I have a 6 qt kidney tank and have run 6, 5, and 4.5 for a beta test.
    11,399
    I never run more than 3.25 qts, add when it gets to 2.5. Try 3 qts and see if it stops.
    Also, don't trust marks on stick, add a qt at a time and check against stick marks
    Thanks rjhamann thanked for this post
    8,024
    You probably want that ugly oil/water mix to go overboard and cause global warming. Having cleaned a few of those tubes, I don't want any part of that back inside my engine. Looks like σκατα.
    Likes mixer, cubdriver2, yellowbird69 liked this post
    Nov 2015
    103
    I built a wood fire in the house today, warming is happening! I probably shouldn’t worry about the small breather tube issue as the smoke system will be going on soon and the belly will soon be BATHED in oil, but I like making stuff more difficult than it has to be.
    I wonder if there is a correlation between high compression continentals and breather tube oil issues.
    Jan 2016
    102
    cubdrvr's Avatar
    Jan 2002
    1,441
    I'm wondering.........how much case pressure in small engines? Depend on blow-by? I'm assuming that case pressure is not necessary and robs horsepower. Would a larger case vent decrease pressure and therefore reduce the vent pressure.......say a 1" or greater case vent vs. the 3/8-1/2" ?
    stewartb's Avatar
    Wolf Lake, AK
    7,784
    I have the crankcase vacuum and oil separator on my IO-390. It works great. There was a thread this spring where I tested crankcase pressure using the vacuum and without. It works as advertised. I’ve never had a drip of oil from the Cub on the hangar floor.
    Nov 2015
    103
    Oh… now THERE is a damn good idea. I know for a fact my vent doesn’t have that little beauty on in. And venting it over the top is also a a good idea. Maybe not for winter ops but summer I don’t see an issue with that freezing and plugging up.
    Bet that 3 inch tube will fix the problem 100%.
    stewartb's Avatar
    Wolf Lake, AK
    7,784
    Jan 2016
    102
    11,399
    Little Continentals don't like more than 3 qts or they blow it out
    Likes BC12D-4-85, Crash, Jr. liked this post
    Feb 2006
    Maine
    844
    ike they have said above the extension and over the top really helps. and as Glenn said the matings on some of the sticks are way off. I like 4 qts have more issues with leaks than blown out oil.
    RaisedByWolves's Avatar
    Feb 2005
    4,858
    I have an 85 that i recently put new cyl and broke in, had been fine for 50 hrs, not using much, but put the long breather elbow and its blowing a qt out every 2 hr. 3 qts max in the sump. Compression didnt show any low cyl. Not sure what changed. Just swapped the elbow back and going to see. put a baby bottle on the end of the breather to see how much its pushing out
    12,540
    Where is the oil coming out? The breather? The exhaust? A compression test will not show a bad oil control ring.
    Feb 2005
    4,858
    Oil On My Belly
    Yes breather into the baby bottle, guess I’m too used to working on lycomings
  1. I Got Your Belly Pod Right HERE!
    By SJ in forum Video Vault
    Last Post: 12-30-2014, 10:57 AM
  2. Belly Pod for PA-12
    By Seaworthy in forum Products, Purchases, Reviews & Prices
    Last Post: 08-02-2010, 11:36 PM
  3. To Belly bod or not to Belly pod, that is the question
    Last Post: 10-19-2006, 04:43 PM
