Results 1 to 9 of 9
Thread: Shake your tail feather
    Meanwhile,...
    5,538
    A couple days ago I was giving the Super Cub a Pre-Flight before an early morning mental floss flight and as I did my regular routine of walk, wiggle, touch and pat I gave the tail a wiggle and while looking down I noticed movement at the tail-wheel to spring connection. Never had that before, the Ni-lock nut had loosened a bit allowing for it. So a few seconds with the appropriate pair of channel locks (just kidding) and it was back tight. I typically change the bolt every annual or so and always the nut so it hadn't been that long. Anyone else seeing such?
    12,261
    One of our Goose drivers was preflighting a Goose. There had been a big wind storm recently and the Goose was outdoors during. Pilot walked up and wiggled that BIG rudder, and it fell off.
    Didnt fly that day.
    Likes BC12D-4-85, RaisedByWolves liked this post
    Dec 2016
    Canyon, tx
    1,036
    I’ve wondered if it’s more bolt stretch than nut loosening?
    Likes AkPA/18, Oliver, joemcd, ak49flyer liked this post
    Grant's Avatar
    At Work.....
    2,038
    I have one that I take care of and its always loose. It's a real heavy airplane. going to suggest a two bolt tailwheel for him next annual.
    7,967
    I had a leftover NAS bolt, so I used that. 167,000 psi. Needs a special washer, but lots stronger.
    Dec 2017
    NE
    89
    My tail wheel was loose because the spacer had wore, welded the spacer up, ground down to fit snug and no more loose tail wheel.
    22,072
    AN363 steel locknut tight but agree with Kevin. See lots of loose tailwheels.
    Apr 2009
    AK
    311
    They’re almost always loose at annual. I’ve thought it has something to do with the bolt going through two leaves that slide in relation to each other, somehow loosening or wearing over time. Agree with Steve- lose the castle nut if you have one, put a nylon locknut on there, and keep an eye on it. Fwd bolt loosens sometimes too, but not as common.
    Meanwhile,...
    5,538
    Quote Originally Posted by ak49flyer View Post
    I participate in owner assisted annuals with my A&P so I see what's loose and such first hand, never had this and its a nylock.
    Thanks all and I will check the bushing.
  1. Cub/Super-Cub tail feather repair
    By tcbetka in forum Piper: PA-18 Super Cub (and L18C & L21)
    Last Post: 09-24-2020, 05:31 PM
  2. The Petro Point Shake
    By Patrol Guy in forum Video Vault
    Last Post: 03-03-2013, 06:52 PM
  3. Tail feather Assembly Problems
    Last Post: 08-30-2008, 08:16 PM
