Results 1 to 8 of 8
Thread: 10pt Oil Pressure Change
    Dec 2015
    East Texas
    108
    Question… I have a new to me Cub that over the last couple of months has lost about 10 psi of oil pressure. I was consistently seeing about 75 psi and now it is at 65 psi. At idle, the low pressure indicator now flashes and is making about 20psi.
    I was originally chalking it up to warming ambient temperatures but this airplane also ate a wrist pin cap and sent some aluminum through the system a while back. It was addressed but I am wondering if there is a chance that there might still be some lingering shavings causing a partial blockage.
    Any thoughts?
    2,980
    How much time on the engine total and how long since bottom end was open? Do you have a screen or oil filter? Is it still making metal? At what RPM are you seeing the high pressures mentioned? DENNY
    stewartb's Avatar
    Wolf Lake, AK
    7,739
    Have you cleaned your suction screen?
    4,852
    What engine is it?
    12,526
    Remove and clean out the oil pressure relief ball and spring located on the upper right rear side of the crankcase. A spec of carbon getting stuck under the ball can do this.
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    318
    mine did the same thing. New spring and ball and its rock steady again.
    Likes TxAgfisher liked this post
    Dec 2015
    East Texas
    108
    160hp Lycoming. Last filter was mishandled and thrown away but I’ll be cutting this one soon. I’ll check the pressure relief ball as well - was wondering if that’s where I needed to start or if there was any other place something might be hiding.
    Likes DENNY liked this post
    2,980
    The pressure relief ball is a quick and easy thing to check so starting there is a good Ideal. DENNY
  1. Replies: 5
    Last Post: 06-08-2020, 11:57 AM
  2. Replies: 15
    Last Post: 11-30-2014, 10:16 PM
  3. Change in CG effecting stick pressure.
    By Steve Pierce in forum The Art and Science of Flying
    Last Post: 02-19-2003, 10:56 AM
