Results 1 to 7 of 7
Thread: Mowing my 6 acre runway in 32 minutes
    RanchAero Grand Vista, Brooksville
    2,648
    A faster better way to get it done. The entire rig was under 10K and works very well. I cut at the maximum recommended speed published by the Swisher manufacture which is around 5 mph.
    https://youtu.be/zTFr_GrpTZc
    Likes jrussl, flybynite, Coondog, Richgj3 liked this post
    Flyingde's Avatar
    Mar 2018
    NC
    75
    Nice! If you want to see that taken to the next level Google Triple tree Aerodrome mower….
    2,648
    Wholly smoke. I got nothing. That thing is very impressive. https://youtu.be/fK67j2HKkqc
    But there is one little difference. $8K vs $800K
    Likes courierguy, WindOnHisNose liked this post
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,156
    I use a Jacobson 5' flail mower, 3 bangar Kubota powered, I got a deal on it and then refurbished it, on my .16 acre runway, sometimes the 6' brushhog if I already have it on the rear of my Kubota L3301. Either one takes about 10 minutes, no one ever said life was going to be easy!
    Sep 2014
    Fairvew East (Crane Road Airstrip),Wasilla, AK
    79
    I would add my testimony to this as regards the performance of those Swisher tow-mowers. We mowed our 1900 ft runway and 4 acre "yard" without help (now we have neighbors who fly and help) for a decade with only one of them. Ours also has adapter bars and swiveling front wheels that allows for fixed mounting in the front of a 4-wheeler. It is easily the most efficient, least expensive, and lowest maintenance machine we have ever had for the job.
    12,360
    Fortysix12,
    i know this is just a lawnmower. But when looking at the design (0:24 in the video) there is a welded 90 degree joint which takes a tremendous amount of load trying to break it, opening the 90* angle. I would run a piece of something from outboard on the mower to where the red piece connects to the tow bar completing the structural triangle. I can hear you from here, when you are at the far end of your strip and the mower separates from the rest of the rig.
    2,648
    Skywagon8a, You are correct. To be honest this was a semi temporary configuration but it worked out so well I never changed it. One reason for minimizing the support structure is because the angle would have to be removed to service the JD Hog tires or unbolt the entire rear tire system from the bush hog. The angle is is .375 thick and I did weld it on two sides. You would be surprised at how maneuverable the trail mowers are . There is less strain then you might think. But to be bulletproof a triangle gusset would be needed. My biggest problem was bouncing the hitch pins out and loosing the mower, solved that using spring pins. Thanks for your input. I will say that I'm amazed how nice the bushhog cuts with sharpened blades yet its rated up to 3 inch saplings.
  1. 7 minutes well spent!
    By flyrite in forum Lighter than Air - Flying Humor
    Last Post: 12-21-2018, 09:32 PM
  2. Some guy sat for a few minutes engineering.
    By tempdoug in forum Cafe Supercub
    Last Post: 03-18-2015, 11:44 AM
  3. What's the best type of tractor for mowing strip?
    By pzinck in forum Cafe Supercub
    Last Post: 09-07-2014, 10:08 PM
  4. Build a B-24 every 55 minutes?
    By NimpoCub in forum In The News
    Last Post: 07-30-2013, 09:20 PM
