Shop ordered 1280HDs. Aircraft is a lightweight 160 Super Cub used on paved airports only.
Would 1080HDs be better for weekend flying? Pilot is a 120 lb blonde. Rarely carries passengers.
Also I note that the Hydrasorb ears can be rotated 90 degrees so I can use the J3 installation tool. Is there any difference? I am set up with the floor jack, so I can go either way. The J3 tool spreads the cord for easy installation over the ears.
Thanks.
