jimboflying
The ATR Dittel radio in the glider works fine when output is to a speaker. With a regular headset the voice volume is very low even when maxed out when using a Lightspeed or DC headset. If an old Telex is used the volume seems more appropriate. The socket seems to have a resistor soldered across it. Can anyone tell me what I must do to be able to use a modern headset?
