Results 1 to 26 of 26
Thread: Gap seals
    11,257
    Gap seals
    Looking for thread we had a couple weeks ago on gap seal tape
    11,257
    Sooo I put it on top, 2" with a 3/4" opposite middle bottom tape
    12,174
    Like this. When the surface moves it will remain the same tautness. The way you show it, it will be tight when the surface moves one direction and loose when it moves the other direction. There was a bulletin to do this on the Bellanca years ago.
    Likes TxAgfisher, courierguy, sjohnson liked this post
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,140
    I found some neutral colored foam weather stripping that perfectly seals the gap between my horizontal stab and my elevator on the RANS, and gained 3 MPH top speed and knocked off 2 MPH off the stall! No, not really, but it makes me feel better knowing it's back there and it doesn't add any weight, and I had it leftover from sealing up my doors.
    12,174
    Was there any speed change? With a fixed stabilizer and a trim tab on the elevator, the two surfaces are not always perfectly aligned. Therefore there could be some tendency for air flow along the hinge line creating a minimal amount of drag. Don't know if it is measurable, particularly on slow airplanes.
    cubdrvr's Avatar
    Jan 2002
    1,378
    Blenderm .... position elevator to its lowest point and just tape on top the length of the gap.Cut out for hinges
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,140
    My thinking also, it HAS to help. Can't hurt anyway....and other than any "speed increase" (I spend a lot of my time in the 70's, because I like it there) and drag reduction will help climb, range/duration, glide etc. Unless there is a major drawback (like ditching the 29" Airstreaks for 6:00's would be) I'll clean things up when possible.
    May 2017
    1,400
    On gliders we use Mylar tape for gap seals, wide enough to cover the gap, double sided tape on the fixed surface to adhere the Mylar. If you are worried about scuffing the movable surface, put Teflon tape on that.
    Likes mixer, Delta Cub liked this post
    12,174
    This is another method. Balsa wood faired and glued to the surface leading edge, covered with a fabric tape. Does it work? Don't know, as it was installed before the first flight. It does close the gap.
    Likes RaisedByWolves, KevinJ liked this post
    Kodiakmack's Avatar
    Sep 2020
    winters in Utah, Summers in Idaho
    225
    Any link for a kit for pa-12 with -18 feathers?
    HAVE FUN. DON'T DIE.
    Scooter7779h's Avatar
    May 2004
    Anchorage, Alaska
    1,106
    Quote Originally Posted by Kodiakmack View Post
    I got mine field approved. 11 pieces of paper but walked into FSDO dropped off the application, had a cup of coffee and picked up signed 337. You need to buy the PA-18 STC and have previously approved PA-18 tail feathers to go the way I did.
    PA-12 fan
    11,257
    I don't think I like it?
    12,174
    Just curious, what don't you like about it?
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY & Middlebury, VT
    2,909
    Maule Aircraft does it this way at the factory .
    Transmitted from my FlightPhone on fingers…
    3,671
    Not to discourage but tape and fabric can become a trap for snow and ice. Clean it out before flight. Spruce sells a foam seal for Pitts I stuck in my Taylorcraft gaps. Floats in place ok not glued.
    11,257
    Stick was heavier at same speed
    Utah-Jay's Avatar
    Aug 2020
    Heber City, UT
    417
    My buddies CC has a foam gap seal between his H-stab and elevator
    12,174
    That means it works.
    11,257
    I knew you were going to say that
    3,671
    My goal for the Taylorcraft's seals was to improve elevator trim effectiveness. 1941's had a small elevator tab, later after WWII they enlarged it - like double in length. Now at constant power I can fly via trim full nose up about 5 mph slower - 55 vs 60 IAS. More nose up authority from the seals I guess.
    Sep 2014
    Fairvew East (Crane Road Airstrip),Wasilla, AK
    71
    What do we know about this stuff?
    https://store.cubcrafters.com/Foam-G...18_p_1298.html
    3,671
    What's the real question is why the designers of tail surface gaps left them so large? Surely the obvious leakage of air through them didn't escape their observation?
    12,174
    The real answer is Who cares? The airplane has adequate control function in order to pass all the required FAA (or in the case of these planes CAA) tests. The desire to close the gaps is only a personal pilot owner thing. Sure they do something, but they aren't necessary to satisfy the FAA. Perhaps their installation is only to cover up some poor piloting techniques?
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    817
    Quote Originally Posted by salex View Post
    It is used on the FX-3 elevator and rudder. I've had mine for about 2 years and about 200 hours of flying. They are easy to fit and remove but they don't fall out. No sign of deterioration in 2 years but the aircraft is hangared. I was concerned that dust and dirt would get trapped in then and abrade the paint but no problem so far.
    3,671
    Bellanca cared enough to close the gaps on their 7GCBC and 8KCAB. Likely others that are promoted for aerobatics but I've not checked. Brisk empennage control authority is desirable by some while exercising proper piloting technique. Then there's the aileron gap seals that promote STOL and roll rate on Cessna's and again Bellancas.
    Likes mixer liked this post
    12,174
    This is the question I was answering.
    A manufacturer can chose for whatever reason to close or leave open the gaps. The only question they need to answer is "Will it pass the FAA flight tests?" There could be any number of reasons to close or leave open the gaps. Some reasons you may not even think of.
  1. Gap seals
    By womblesd in forum Modifications
    Last Post: 07-02-2021, 08:55 AM
  2. Pa-18 gap seals
    By ExConPilot in forum Member to Member
    Last Post: 05-07-2020, 05:55 PM
  3. Gap seals
    By NimpoCub in forum Modifications
    Last Post: 09-13-2018, 06:55 PM
  4. Gap seals
    By SchulerJL in forum Member to Member
    Last Post: 08-14-2011, 07:00 AM
