Page 1 of 2 12 LastLast
Results 1 to 40 of 47
Thread: Intermittent Strobe Light
    Cardiff Kook's Avatar
    Feb 2020
    Sisters, OR
    633
    I don't know anything about how the pictured strobe light works- but it's gone intermittent on me.
    I can hear it going "click, click, click" very quietly, but it's not firing.
    Then it will fire/light out of the blue.
    Is it the bulb? if so, where do I get another and is now a good time to switch out for LED?
    5,052
    It's always a good time to switch to LED's.
    You most likely have a bad strobe tube. To verify that, swap it out with the opposite strobe tube. If the problem follows, the tube is bad. If the problem stays, the power supply is bad. But you HAVE to troubleshoot before you start buying parts.
    Likes DENNY liked this post
    Feb 2020
    Sisters, OR
    633
    Understood. Could the tube be bad and work intermittently, or do they work or not work?
    5,052
    They can sometimes come on steady but very dim, and then flash once in a while. Swap the tubes side to side and see what happens.
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,472
    Quote Originally Posted by Cardiff Kook View Post
    There is a description of some failure modes in this article:
    https://en.wikipedia.org/wiki/Flashtube
    More here -
    https://www.beauphoto.com/demise-of-a-flashtube/
    Grant's Avatar
    At Work.....
    2,103
    I have these tubes coming out of my ears if someone needs one.....
    5,052
    Dr Randy might have a shot to cure that . . . .
    SJ's Avatar
    Jan 2002
    Northwest Arkansas
    16,315
    I thought strobe lights by design were intermittent?
    sj
    5,052
    sj
    I want to see how you drive through an intersection with a flashing red light!
    SJ's Avatar
    Jan 2002
    Northwest Arkansas
    16,315
    Very carefully....
    Superbill's Avatar
    Dec 2021
    Lostine Oregon
    37
    sj
    I checked out this thread just to see who was going to say it!
    Feb 2020
    Sisters, OR
    633
    sj
    Nice!
    Supercruiser46's Avatar
    Jul 2019
    China, Maine
    30
    Quote Originally Posted by Grant View Post
    Hey Grant, do you still have some of these? I have one that keeps stopping and taking a break every few seconds too so I'd purchase one if still available.
    Mike
    Grant's Avatar
    At Work.....
    2,103
    Yes - PM Sent
    8,858
    Has anyone ever had an intermittent strobe that was caused by the flash tube? Failure of electrons to reach the tube, yes, but in my life tubes either work or they’re done. No middle ground.
    5,052
    I've seen them fail a couple of ways. Some will come on as a steady, dull glow, with no flash. The other way is for them to come on and flash a couple of times and then nothing. Occasionally, that type of failure may flash once in a while, if you just leave the switch on.
    Feb 2020
    Sisters, OR
    633
    finally got around to swapping tubes. The tube works on the other side- so its not the tube.
    The power supply was new in 2019- any chance it is something else?
    Feb 2020
    Sisters, OR
    633
    And shouldnt there be no continuity between two wires on a light when the switch is closed? I have continuity with a closed switch on both nav and strobe on both wings with all switches off.
    5,052
    Single power supply for all strobes or separate power supply for each?
    If single power supply, the power supply is bad.
    If separate power supplies, you'll need to troubleshoot the power and ground wires. Ground the black lead of your meter to the spar. With the master 'on', the strobe switch 'on', and the power supply connected, there should be battery voltage at the power supply connection and zero volts on the ground connection. Less than battery voltage at the power connection means a bad connection on that circuit. If you sea any voltage on the ground wire, it means a bad ground terminal.
    Likes Cardiff Kook liked this post
    5,052
    . . . . with a closed switch on both nav and strobe on both wings with all switches off.
    A 'closed' switch is in the 'on' position unless its a magneto switch.
    Feb 2020
    Sisters, OR
    633
    I meant “open switch.”
    The strobe and master switch are off
    Feb 2020
    Sisters, OR
    633
    Thanks. Pardon my ignorance here but what what is the positive lead of my multimeter connected to? Do i want the bulb in or out or not matter?
    Feb 2020
    Sisters, OR
    633
    And what happens if i hook the multimeter up to the powersupply output? Or is too much voltage?
    13,028
    That output is VERY high voltage.
    5,052
    The red lead goes to each of the connections described, i.e. power wire or ground wire, at the power supply.
    And leave the strobe tube connected.
    5,052
    Unless you own a very expensive meter with special high voltage leads, very bad things will happen.
    May 2003
    Ambajejus Lake, Maine
    52
    I just removed a strobe power supply. I am redoing the wiring on my experimental-12. If you need a replacement I have one to part with.
    Feb 2020
    Sisters, OR
    633
    I think i got it- so i need the power in connected and need to get a multimeter at that connection- probably using the needle to slide under the connector.
    Bear with me here as this is foreign to me.
    Why would a voltage at the ground indicate a faulty ground?
    5,052
    [QUOTE=Cardiff Kook;850999
    Why would a voltage at the ground indicate a faulty ground?[/QUOTE].
    Your black lead is on the spar which is ground. A bad connection of the ground wire to the airframe ground creates a high resistance which, in turn, is indicated by a voltage.
    Likes Cardiff Kook, akmarty liked this post
    Feb 2020
    Sisters, OR
    633
    web- i am seeing 12.6 at battery and 12.4 at the power supply in connection. Is that my issue?
    Feb 2020
    Sisters, OR
    633
    Actually battery is 12.9 and drops off at battery when strobe on
    5,052
    Where did you place the leads to measure that voltage?
    Feb 2020
    Sisters, OR
    633
    On battery on pigtail for trickle charger.
    At strobe on power in lead with negative clipped to a small part of the wing frame. Not sure what it was.
    Likes A very stick puppy liked this post
    5,052
    Those are good readings, then.
    Feb 2020
    Sisters, OR
    633
    So is that an issue? The opposite side has similiar readings and it is operating fine.
    Likes jrussl liked this post
  36. #36
    5,052
    No issue with the voltage.
    Do you have a single power supply for all strobes or do you have one power supply each strobe? As you said earlier, you swapped the tube to the other side and it worked. So that leaves the power supply.
  37. #37
    Feb 2020
    Sisters, OR
    633
    one power supply each side. Power supply was brand new 4 yrs ago so hard for me to believe it is shot.
  38. #38
    5,052
    OK. So explain to me why it can't be the power supply when you have the correct voltage to the power supply and the tube has been tested good on the other wing.
    Likes BC12D-4-85, CubCruiser, bcone1381 liked this post
  39. #39
    Feb 2020
    Sisters, OR
    633
    i cant. I just dont want it to be the power supply🤣.
  40. #40
    1,656
    So to confirm, move the power supplies side for side and see if the problem follows the power supply!
  1. LED Nav and Strobe light options
    By tbone in forum Modifications
    Last Post: 03-23-2023, 08:00 PM
  2. 1951 PA-18 Strobe Light 91.205
    By Cardiff Kook in forum Cafe Supercub
    Last Post: 06-29-2022, 12:52 PM
  3. Strobe light on PA18A -150 1959 model
    By Bob Stern in forum Tips and Tricks
    Last Post: 01-03-2021, 08:40 PM
  4. SkySensor ADS-B In green nav/strobe light
    By Eddie747 in forum Cafe Supercub
    Last Post: 07-01-2019, 10:28 AM
  5. Replies: 3
    Last Post: 07-03-2013, 09:54 PM
Tags for this Thread
