Results 1 to 14 of 14
Thread: One of my Fuel Balls Sank
    C-185's Avatar
    Feb 2005
    Nome, Alaska
    173
    I checked my fuel tank before a recent flight, full by the touch. Went flying and noticed my bright orange ball at the bottom of my sight gauge. I burned about half of a tank and the ball came up a little. Landed and after tying down the plane the ball was at the proper fuel level. Checked the next day and the ball had sunk again. Some history, I changed this ball less than two years ago when I had the sight gauge apart for cleaning. Do they lose there buoyancy? I have flown cubs for a long time and have never seen it......... Maybe I got some bad balls?
    My superior skills continue to get me out of where my piss poor judgement took me......
    12,142
    Quote Originally Posted by C-185 View Post
    Hmmmm, “bad balls”…….that’s likely to take the conversation in interesting realms.
    Likes stid2677, alaskadrifter liked this post
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,294
    Happened a lot on the early Legend Cubs. As I recall they would stick. I think we got new gauges. The first service instruction just said to remove the balls and put some white paper behind the sight tube so the fuel could be seen.
    It was a while ago. My memory may be sketchy.
    Rich
    7,899
    As long as they aren't blue . . .
    Likes Delta Cub, RaisedByWolves liked this post
    Oct 2009
    Wanaka,NZ
    389
    Both mine sank within two years .Just usual crap available today.As we are experimental I am going for transparent tubes.Eliminate another possible incident.Will use fuel resistant tubing, being aware the transparency may diminish over time.
    nightflyer's Avatar
    Jan 2012
    Colleyville, TX
    110
    I think one is supposed to be lower than the other.
    21,942
    ADK_Cub's Avatar
    Jun 2019
    30
    One of my cork balls sank, figure that.
    Oct 2009
    Wanaka,NZ
    389
    Hi Nightflyer,can you elaborate please.
    Quote Originally Posted by nightflyer View Post
    4,520
    Quote Originally Posted by ron View Post
    It's the theory of impenetrability: No two objects can occupy the same space at the same time.
    nightflyer's Avatar
    Jan 2012
    Colleyville, TX
    110
    I think Kevin Johnson can explain it best.
    Dec 2016
    Canyon, tx
    1,012
    Like most, I’d have got a lot farther in life if my balls would have never dropped.
    Bayou Navigator's Avatar
    Jul 2006
    Louisiana Swamp
    120
    Nah.
    When everything is going wrong, and the world is bearing down on you.......GO FULL THROTTLE!!!
    Feb 2021
    Fairbanks, AK
    12
    A couple years ago I refurbished my sight gauges with new gaskets and Univair plastic orange balls. I had read all the horror stories from this sight about gaskets/breaking glass/bad balls etc. Well, within six months my right hand side orange ball started "submarining" like described by the OP. Most of the time that stupid ball is at the bottom, but I do see it at the top or somewhere in between sometimes. Frustrating to go through fixing up all nice and then to not work shortly afterward. The good news is no leaks or broken glass and I can clearly see the fuel level so I don't plan on installing a new ball anytime soon. From my experience and other cub pilots I know, yea this seams to be an regular issue with these cub gauges.
    Thanks ron thanked for this post
  1. Sinking Balls
    By Binty in forum Modifications
    Last Post: 01-01-2018, 06:40 PM
  2. Handprop with Balls
    By Eddie Foy in forum Cafe Supercub
    Last Post: 07-20-2016, 09:57 PM
  3. Little red balls????
    Last Post: 02-15-2005, 12:19 PM
  4. Little Orange Balls
    By SJ in forum Tips and Tricks
    Last Post: 09-25-2002, 08:57 PM
