But when was the last time anyone used a 337 to install an aluminum cooler in place of the original brass one? If you take the above logic, then just using a different part number cooler would require a FA or similar documentation.
Unless the replacement is PMA’d for the PA-22 and is installed the same way. PMA is a design approval, manufacturing approval and installation approval.
