Results 1 to 9 of 9
Thread: Air Tech Coating question
    May 2019
    10
    I’m looking at a Cub with Air Tech Coating finish on it. You can see daylight through all the fabric. Is this acceptable?
    I’m new to Air Tech Coating and appreciate your help.
    Dec 2016
    Canyon, tx
    985
    Yes I believe is the answer. Call Robbie at Airtech and he’ll explain it. The cub I owned for several years had the process and it showed very well.
    cubdrvr's Avatar
    Jan 2002
    1,352
    I've done a few with Airtech.....last one in 2000 on my cub.......22 years and it looks great.
    Only issue I've had is small cracks in the finish on the leading edge of the horizontal stabilizer.
    Likes jrussl liked this post
    21,816
    Yes, seeing light through AirTech is normal. It blocks the UV instead of reflecting it is how I was told it works.
    JP's Avatar
    Mar 2003
    The Big Woods of Maine
    3,327
    Mine is coming up on 18 years. No issues except minor hairline cracks in one or two places where I put on too much paint. I expect that they can be gently sanded out and spot recoated. It still looks really great. I did a cross-coat and a half of the UV primer gray and don't seem to have much translucence.
    JP Russell--The Cub Therapist
    1947 PA-11 Cub Special
    May 2019
    10
    With out telling my age I started my first cover job with grade A cotton. Of course then moved to dacron. This was the first Air Tech cover job i have ever seen. when I looked back in the fuselage and it looked lighted like the lights were turned up bright I didn’t know what to think. As KevinJ suggested, I called Robbie at Air Tech and he explained it exactly as Steve Pierce noted above. Thank you for the help.
    Bozo
    (that’s what the grandkids call me)
    Likes jrussl, Steve Pierce liked this post
    Apr 2002
    Sherwood Park, Alberta, Canada
    124
    Most modern windows block damaging UV-A and UV-B rays. Also sunglasses, sunscreen and automotive clear coats block the damaging UV rays. There is a big difference between UV light and visible light.
    supercrow's Avatar
    Dec 2008
    610
    I mentioned that a while back in another thread. Visible light in any of the covering systems is not necessarily a bad omen. You can't see the UV light that is harmful to fabric jobs.
    7,822
    Never used the Airtek system, but have used their topcoat over Stitts Poly white. Results are spectacular. One gallon plus thinner and catalyst did an entire Cub wing, several large repair areas, and a large four wheel tug.
    I did the prep, and had a "pro" spray the final coat. Cannot see through the fabric.
  1. Fuel Pump Tech Question
    By stewartb in forum Super Cub Repair Facilities
    Last Post: 03-15-2020, 08:26 PM
  2. Atlee Dodge/Powder Coating Question
    By Steve Pierce in forum Tips and Tricks
    Last Post: 12-14-2014, 12:34 PM
  3. Tech question: Lowrance GPS feed to E.I. Fuel flow gauge
    By moneyburner in forum Super Cub Sick Bay
    Last Post: 05-21-2009, 11:53 PM
  4. ski tech question..
    By AK-HUNT in forum Cafe Supercub
    Last Post: 11-09-2006, 12:22 PM
Tags for this Thread
