Installing a new set of 35" bush wheels on a 1 1/4 axle. When trying to install the axle side spacer the rosette weld on the stub axle will not let the spacer past about half way. Has anyone else had this issue? Have a call and email out to ABW but seeing who else is up early.
Worse case I can machine the inside of the spacer where it interferes with the rosette weld on the stub.
