Results 1 to 8 of 8
Thread: 1 1/4" axle kit fit interference
    Feb 2017
    Vermont
    67
    Installing a new set of 35" bush wheels on a 1 1/4 axle. When trying to install the axle side spacer the rosette weld on the stub axle will not let the spacer past about half way. Has anyone else had this issue? Have a call and email out to ABW but seeing who else is up early.
ID:	60991 Click image for larger version.
ID:	60992 Click image for larger version.
    Worse case I can machine the inside of the spacer where it interferes with the rosette weld on the stub.
    The engine may be the heart, but the pilot is the soul
    NDRII's Avatar
    Aug 2003
    Back in No. VA again
    126
    I had the exact same issue. Answer from from Airframes 7 years ago was sand down the weld flush. 5 minutes with a 1/2 inch pneumatic belt sander and it has been just fine.
    Norm
    7,851
    I take it those wrinkles were there when the gear leg was covered?
    Feb 2017
    Vermont
    67
    Yes, they have been there sense the aircraft was acquired. Next summer the goal is to get a new set of extended gear for it.
    2,792
    How old is that gear? You might want to peal that fabric off and take a good look at them before you hang a set of 35 in tires on them. The lever arm of the tire is pretty long, I have seen BOTH a stock HD and 3 in HD gear bent in the middle when the cub got sideways. Bob is being polite when he asked about the wrinkles, think about it no one leaves wrinkles like that when you cover. Fix the brake line so you are not traping a air bubble while you are at it. Sorry to make more work for ya just trying to help prevent big issues down the road.
    Likes jrussl, Crash, Jr. liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    908
    In my opinion the brake line is not an issue. Most covered gear will have the brake line exiting the fabric below the axle and that's just the way it's done. Lots of cubs running around with brake lines just like that and no issues. Your brake bleeder is located on the bottom which is the better way to go so that should work fine.
    As NDRII said, just grind/sand down the head of that rosette weld and also probably remove all of that paint. The spacer ID is fairly exact so it will be a tight fit if you have any extra paint buildup on the axle.
    21,893
    Aren't those the welding rods welded in there to support the wheel pant bracket?
    Feb 2017
    Vermont
    67
    Thanks for the help gents! One small project always seems to turn into more work than expected! Successfully got the 35's on, gear un covered, painted, re-assembled, brakes bleed, and test flown.
  1. Switching Cleveland wheel from 1 1/2" to 1 1/4" axle size?
    By Dan Gervae in forum Experimental Cubs
    Last Post: 11-09-2016, 09:57 AM
  2. 3" extended gear and axle placement
    By skukum12 in forum Cafe Supercub
    Last Post: 05-01-2014, 09:15 PM
