Can anyone confirm if this would be the correct piece? I have found many of Univair's parts seem to fit everything ever made.
https://www.univair.com/piper/piper-...kaAmHZEALw_wcB
Yes its correct. 3/4” shank if memory serves correctly. I have a brand new one of those I’m not going to use. PM me if interested.
PA-12 N418BSmixer liked this post
Just remember you will have to get it drilled (by a shop or you) for the two holes that are in the original one. I'm getting mine done this summer come annual.
Jeremy Vaughan - VA & NC Ambassador
Recreational Aviation Foundation
jvaughan@theraf.org | theRAF.org
I have a used one if you need it.
A used one will not work. The rudder is custom drilled to the steering arm. Those holes get wallowed out and the arm moves inside the rudder. Dakota Cub has a machined steering arm that fits better than the cast one that Univair sells.
I remove the rudder, square everything up on a table and carefully back drill from each side for the two 3/16" bolts that hold the steering arm to the rudder.
If it was easy everyone would do it.![]()
