Results 1 to 15 of 15
Thread: Auto gas stc
    OVEREASYGUY's Avatar
    May 2005
    New Gloucester, Maine
    415
    Auto gas stc
    My pa-18 has an stc for autogas.
    engine was overhauled & I assume the stc remains.
    Recently I put a new carburetor on. Does that change anything? Are new carburetors built to withstand ethanol?
    When they say I have stc for auto gas does that mean gas with ethanol is ok? Im going on floats this summer & built a super cool fuel trailer. Id love to be able to run Autogas from the local gas station.
    your advice would be greatly appreciated.
    cliff dow jr in maine
    54ME cliff dow airport
    dow.us
    11,345
    I've burned over 1000 gl of ethanol mogas. Half of it untreated. If your stuck and have to buy it use it up as fast as you can, if it sits it will absorb water and loose BTUs. Best thing is to carry the Startron and treat it when you buy it.
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    309
    Read the STC. Pretty sure it will EXCLUDE the use of ethanol fuels. It is in great big letter on the Peterson website. DO NOT USE FUELS CONTAINING MOONSHINE (ethanol)
    Thanks supercub83a thanked for this post
    Likes jnorris liked this post
    3,939
    Read the STC.
    The EAA STC I for my C180 (EAA) says "do not use fuel that contains alcohol" about 4 times in the installation instructions.
    And the required placard adjacent to the fuel caps says that.
    As I recall, the Petersen STC that I had for a previous airplane has similar language.
    From the EAA STC:
    Likes akavidflyer, soyAnarchisto liked this post
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,124
    Sealing the vent off with bread wrapper plastic and the twist tie helps keep moist air from coming and going. A small balloon would work too.
    Apr 2010
    Soldotna AK
    309
    Quote Originally Posted by 180Marty View Post
    seems like a brilliant thing to do on a plane. What could go wrong...
    RVBottomly's Avatar
    Sep 2017
    1,363
    Read the STC.
    My EAA STC says the same thing. Even sent a little jug with instructions on how to test to see if ethanol is in the fuel.
    Feb 2006
    Maine
    843
    Cliff with your million dollar budget just fill the thing with avgas, quit trying to cheap out.
    Likes albert kasemodel, akavidflyer liked this post
    7,960
    For the last three weeks here in sunny Socal Avgas has been cheaper than regular car gas.
    Likes 180Marty, Brandsman liked this post
    jnorris's Avatar
    Wisconsin
    922
    Quote Originally Posted by RVBottomly View Post
    EVERY EAA STC will say the same thing. No ethanol is allowed (or any form of alcohol for that matter).
    To the OP's original question, if you rebuilt the same engine to the factor specification your STC will still apply. And as long as the replacement carburetor is the stock spec, you're good. (No rubber tip float needles though!)
    If you replace the engine with a different serial number (and you have the EAA STC) you need to notify EAA of the serial number change, and have a new Form 337 filled out by your mechanic to apply the STC to the new engine. This assumes that the replacement engine is the same stock specification as the engine that the STC was originally applied to.
    Joe
    Fortis Fortuna Adiuvat
    3,939
    Quote Originally Posted by jnorris View Post
    .......If you replace the engine with a different serial number (and you have the EAA STC) you need to notify EAA of the serial number change, and have a new Form 337 filled out by your mechanic to apply the STC to the new engine. This assumes that the replacement engine is the same stock specification as the engine that the STC was originally applied to.
    I went through this a couple airplanes back.
    Can't recall if I had the EAA STC or the Petersen,
    but the deal was that they issued a new STC for the new engine s/n.
    They charged me the difference between the old price (buck a horsepower) and the new buck and a half).
    3,939
    On a somewhat related subject,
    I saw in the news that federal regs were changed to allow E-15 gasoline to continue to be sold into the summertime.
    Biden will allow summer sale of E15 gas : NPR
    I'm wondering if this latest thing will effect the availability of ethanol-free mogas?
    jnorris's Avatar
    Wisconsin
    922
    Must have been Petersen, because we didn't do it that way at EAA. I handled all the fulfillment for EAA Auto Fuel STCS for the last 3 years of my employment there (I retired this past June), so I know the process. A simple serial number change was no cost. The only time new STC paperwork was issued was when the STC had been originally purchased before 2004 (when the FAA updated EAA's STCs, which resulted in new STC numbers) And even then, it was just a $40 update fee, not the full price of the STC.
    Joe
    Likes jrussl liked this post
    3,939
    ...A simple serial number change was no cost. The only time new STC paperwork was issued was when the STC had been originally purchased before 2004 (when the FAA updated EAA's STCs, which resulted in new STC numbers) And even then, it was just a $40 update fee, not the full price of the STC.
    I looked in my old notes, here's more details:
    the airplane (C150) had been issued a mogas STC back in the day.
    It had since been upgraded to a 150hp Lycoming-- so not a simple s/n change.
    I bought it in 2008.
    I wanted all the paperwork squared away, so I called the STC holder (still not convinced it was Petersen),
    to get a mogas STC for the new engine.
    I was charged the $75 difference between what was paid originally (100hp x $1 = $100)
    and what the current charge would be (150hp x $1.50 = $225).
    jnorris's Avatar
    Wisconsin
    922
    That sounds about right. Not just a simple engine swap, but completely different make/model of engine (and more horsepower). I'm pretty sure both EAA and Petersen would handle that situation in the same manner.
    Joe
    Likes akavidflyer liked this post
  1. Auto Gas Again
    By Patrol Guy in forum Cafe Supercub
    Last Post: 05-13-2010, 11:16 PM
  2. O-360 AUTO GAS..NO???
    By fishcruiser in forum Cafe Supercub
    Last Post: 08-10-2004, 09:01 PM
