Originally Posted by
CharlieN
I have a Hypetherm inverter welder, I love how smooth it is, BUT, it utilizes an air cooled torch only. Yes the control of the arc is nice but anything more than welding thin metal for short time the cable to the torch lets out it's smoke. To me it is kind of useless if I can only weld a few minutes at a time before needing a new torch.
Most air cooled torch cables are considerably stiffer than the water cooled cables/hose setup. It took me along time to find a nice ultraflex power cable. And it was only a 12' cable, the longer ones let there smoke out way too early in a weld session. I ended up machining a custom connector to use a conventional stiff & heavy torch cable allowing me to move around and reach where I need to. That works but I need more than 10 minutes on the pedal to get work done without needing to spend another few hundred on a torch.
