jimboflying
MEMBER
Are there significant differences between brands of fabric for use on an experimental cub? What is best for the Stewart System?
That sounds like something which was discussed at an annual IA meeting years ago. The stamp may be hard to find since it may have been cut off, there is a black continuous stripe which ought to be able to be found. But getting to an annual and not accepting the signature on the recovering 337 is a stretch.Wasn't there an issue some time back of a shop having recovered an airplane without the PMA or what ever its called stamp on the fabric? If I recall correctly the AI could not find the stamp and would not sign off annual.
https://www.supercub.org/forum/showthread.php?50056-Unapproved-Parts-Notification-Dan-s-AircraftWasn't there an issue some time back of a shop having recovered an airplane without the PMA or what ever its called stamp on the fabric? If I recall correctly the AI could not find the stamp and would not sign off annual.
I recall the same thing. When first using Ceconite in the early 60s there were no markings on the fabric.I seem to recall, it wasn’t until some time in the 70s that Ceconite got PMA Stits on the fabric. I think as a result of Stits going the PMA route first. There must have been thousands of airplanes covered in Ceconite from the early 1960s until the mid 1970s that didn’t have PMA fabric and the STC didn’t require it. I think they indicated that their fabric exceeded TSO C15 requirements and was approved via the STC. There were lots of folks, including FAA folks that thought STC was a manufacturing approval.
I maintained and flew a 90 hp Super Cub covered in the light Stits for a long time and had to make lots of repairs on the fuselage fabric on the tail at stringers and longerons.Stewarts is good over any certified fabric, for certified aircraft. They usually sell SuperFlight fabric. Superflight also makes an uncertified light fabric. I still have a 50 yard roll of Stits certified light as well as a 50 yard roll of HS90X. All good stuff, but they just weren't selling enough of the certified light to make it economically viable, was what I was told.
John
I have used Stewart’s system with both medium weight Polyfiber and Ceconite and both work just fine. The airplane I am currently working on is covered in Superflite 101 (Heavy). I was quite surprised at how soft and flexible the Superflite 101 is. Very easy to work with and shrinks very well. I wouldn’t hesitate to use it again.
if you mission involves mostly on airport operations, just use medium weight fabric.
The good news is Jim from Airglass says my pod is getting its final buffing and should ship next week. I had him mold it in black and he says that it’s a real pain but it will look great.
