I'm getting the feeling that the time to replace the floor in a 12 is best done when the aircraft is fabric off for recovering. Without having to do a recover, is it possible to replace the floor fabric on?
While the aluminum does a good job and makes a good scuff plate, the only grip it has is through the screws. A glued on piece of plywood is attached over 100% of it's surface essentially thickening and stiffening the existing plywood floor.Using a repair piece sounds perfect and a LOT easier!!!! I can get 3.6mm birch plywood and obviously aluminum sheet. The aluminum should be a thinner option (would thickness do you use @Steve?) but which gives the most "firm" feeling I wonder? and is the aluminum also glued to the original floor, or screwed to it?
That's outside of my pay grade. I would assume so for most of it anyway.If I glue with PVA do I need to remove all the paint down to bare wood?
I did both front and rear floor boards
many years ago, but managed to do it by myself
and it was with the fabric on. Did pull the bungee fairings
and side panels aft of boot cowl. It wasn’t fun,
but it was doable.
believe I used 1/4” marine grade plywood, w 3/4” (or so) stiffners
on underside to match the old ones. Finished off both sides w urethane.
Still going strong.
