My super Cub has a Sigtronics SCI4H that began making constant noise at some point but I never heard it because I kept a cord plugged into the music jack, then others used my Cub for testing and the complaints started
Bringing it home from Texas the other day I tried everything I could isolate and found the noise only goes away if you
A. Flip the switch to either of the isolation options
B. Plug a cord into the Mini-port for tunes, doesn't matter if there is a devise connected to the cord, its turned on or if there is music playing, the noise goes away.
I'm thinking maybe the plug is the culprit but not sure how to test that.
For now I've back to keeping the plug in it.
