I did a search and apparently the use of non-ethanol auto fuel is an even bigger topic than before. That being said, I couldn't find the comfortable compression level for Mogas use stated as before. I remember threads from years ago and I THINK 8:5-1 was considered doable reliably, has that changed with more years of experience now? Also, I thought I saw a post somewhere that suggested Lycoming Angle Valve engines couldn't take as much compression with Mogas as parallel valve engines, is that correct?Thanks
