Page 2 of 2 FirstFirst 12
Results 41 to 63 of 63
Thread: Building a 4 Seat (4S) Javron Cub
  1. #41
    DJ's Avatar
    Jan 2009
    Bolivia
    420
    "We will be using ATR-FP-251F1 almost exclusively on the 4S (I think)."
    For front floorboards too?
  2. #42
    spinner2's Avatar
    Montana
    1,916
    Kydex .pdf weight chart
  3. #43
    spinner2's Avatar
    Montana
    1,916
    Seat weights:
    I am thinking of going with two Cessna seats on a Cessna track. The weight difference seems to be minor from my weight notes. But if someone reading this knows better, please comment. A front articulating seat from my Cessna with Airtex cushions weighs 13.5 pounds. I'm not sure what tracks weigh, perhaps two pounds per side? I looked at the old W&B from my former PA-18 and have the front seat weight at 12.5 pounds with cushions (I think they were Cub Crafters cushions). But I don't think this Cub seat weight includes the base. Perhaps someone can correct me on this? I no longer own the Cub.
    The nice thing about Cessna seats is they easily slide back and forth, are made as a folder, and slide off of the track very easily if not needed or wanted. And they're comfortable IMO.
    Likes DENNY liked this post
  4. #44
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,615
    Dan - Thank you for posting the information about Kydex, and also the idea of the Cessna seats. I think there is a lot of merit to that. You would probably want Jay to weld in some tabs to attach the rails to, so that you would have a more secure system rather than simply bolting the rails to the floorboard. But I’m sure you already know that and thought of it.
    DJ - Yes, think that right now. You really don't "stand" on the front floor. At least in a cub, so not as much weight is concentrated in a small area. I used the 2ply on the front floor of my current cub and I am thinking it was probably over kill. We will try the single ply and if I don't like it, we can change to the two ply. But my gut feeling is it will be fine. But as someone pointed out, the single ply might "dent" easier, ie a rock stuck to the bottom of a boot, or a dropped tool like an ax, hammer, etc. It is all a trade off.
    Getting started on the paint booth. Man materials are expensive right now. Painfully so. But it’s the price I pay for my own quirks and personality flaws. I just don’t like a plastic/visqueen booth. As I said before, it takes the very best for me to get an average job. And I will probably use it for several projects, and perhaps to help my neighbors a little bit. I’m not much of a painter but if I can help a neighbor, fellow builder, I will try.
    Very Blessed.
    Likes jrussl, Hardtailjohn, SJ, spinner2, Bowie liked this post
  5. #45
    Jan 2017
    PNW
    192
    One thing I noticed about single ply CF with a honeycomb core is that you can see light through it…i.e. liquid passes through it/into it, at least the stuff I used for seat bottoms & backs. Something to consider, especially if you’re going to be on floats.
  6. #46
    Mar 2016
    1,978
    Quote Originally Posted by Mr. Ed View Post
    That depends on what fabric was used in the layup, Not all weaves are that way, and if the fabric is wetted out properly it will be air tight.
  7. #47
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,615
    Folks
    A quick update
    Brad spoke at length to Stein Bruch of SteinAir. https://www.steinair.com If you are not familiar with this name you should be. They are one of the premier avionics shops for homebuilders. They do a LOT of avionics sales and custom panels for experimental types especially the Vans RV group. They have helped several Javron Cub guys. They are in the Minneapolis area and are knowledgeable of Javron Cubs. At any rate, they will be doing Brads panel. Going with the G3X system. Brad sent a deposit to get in the que. We are expecting a Sept or Oct time frame. Everyone is backed up right now so to keep the project moving forward we have to order stuff in advance to account for the lead times.
ID:	60750This is the panel they did for Mark Fiedlers Cub.
    Brad has also decided to have Jay DeRosier build the engine with the help of Lycon. 0-370 with all the bells and whistles at 9-1 compression ratio. We expect to be a little over 200Hp with a weight about 270 pounds. More to follow on both the above decisions.
    Hope this helps
    Very Blessed.
    Likes jrussl, yoop_robaho, Broncoformudv liked this post
  8. #48
    aflyer's Avatar
    Sep 2005
    SW Colorado
    79
    I have know Stein for years, he is well respected in the RV community. I sent him a blank panel, and he cut it out, covered it with a carbon fiber overlay, and silkscreened it. I also purchased the avionics from him. I did the wiring myself, but he will do that too. I was very happy with his service, but there are lead times.
    Sorry about the tilted picture, I was getting bounced around.
    Likes CamTom12, Broncoformudv liked this post
  9. #49
    Nov 2007
    108
    Bill,
    Any updates on the project? I’m interested to see how the plane is coming together.
    Joe
    Likes tgatherer liked this post
  10. #50
    Nov 2021
    Camas, WA
    1
    Bill,
    I occasionally make trips to Sandpoint to visit a buddy and would love to stop in to see your project. I too will be ordering a 4 place cub in the very near future, however I still haven't decided between Airframes Alaska or Javron. I think seeing your project and getting a closer look will help make the decision that much easier.
    Cheers!
  11. #51
    Jan 2015
    Fairbanks, AK
    55
    Despite manufacturing, shipping, global material shortage and inflation issues. If Jay can keep costs relatively moderated I think the decision becomes quite clear. The Airframes fuse was ballpark $21,000. It is now $32,000. To be fair, I do not know of Javron's price adjustments if any.
  12. #52
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,615
    Gents (and Ladies)
    I am really sorry that I have not updated recently. I do have a fair amount of progress to report just as soon as I have 20 seconds to myself. Been super ultra busy. I have spent the last couple of days in the shop with Jay DeRosier working on some design issues which I will talk about when I have a moment.
    tgatherer- I would love to have a visit. shoot me a PM with your contact info and I will respond.
    Standby for updates in the next few days
    Very Blessed.
    Thanks vj88, Bowie thanked for this post
  13. #53
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,336
    I am looking forward to this thread. If things go according to plan, I will be on the list for one myself.
    "Always looking up"
  14. #54
    Feb 2017
    1
    Bill,
    Looking forward to this as a first time builder. My kit is done and I got my first look at Jays finished product at Oshkosh. I'll be spending a couple weeks with Jay over the next couple months. Then it will be shipped to Ohio for me to finish. I'll be following your build closely. Thanks.
    Herman
  15. #55
    Oct 2004
    156
    Herman,
    Welcome to the Javron 4 seater family!
    I should get my kit late September, early October.
    Bill,
    Very interested in the design changes you and Jay discussed.
    Tom
  16. #56
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,615
    Folks
    Wow, time seems to just fly by. Pardon the pun, (groan) but it has been a very busy summer.
    I spent 50 days in Alaska. Stayed in the cabins 34 nights. Stayed in 19 different cabins. Logged 94 flight hours. Had two new visitors and 5 friends total in the cabins.
    Three cubs, 2 are Javron, one a CC top Cub. On floats in Alaska at a Forest Service Cabin. It was a fun summer.
    Here is a video of 3 cubs in Alaska. I will try to do a couple of more videos when I have time. I got a lot of footage this year, just need to edit and put it together. Time.....just not enough time....
    Then I flew to Oshkosh, then the upper Peninsula of Michigan, then to Brainerd to work on the 4S fuselage, and had to work in there as well. Then in a few days I will head to the Greenville fly-in in Maine, and finally get my Cub back to Sandpoint in the latter part of September.
    As I look back on my other thread I have no idea how I found the time to do all that. I have been going in full afterburner since about the first of April.
    So......enough of my issues......lets talk cubs..
    There is sooo much info on "how to cover" on Youtube that I will not go over that here. We are using Airtech and there are TONS of videos at the Airtech channel.
    The tail surfaces, flaps and ailerons are covered, stitched, taped, and ready for primer. Working on getting the wings ready for cover now. I anticipate Brad can start covering one of the wings this evening.
    Although the wings are pretty much built there is still a fair amount of work that must be done prior to cover.
    1) Install position/strobe light mounts. We fabricated ours. You can find info on how we did this in my other thread. (You can also order premade mounts from Jay, saves time and they are beautiful)
    2) install the wires for the pos/strobe lights
    3) install Landing Lights (often shortened to just LL)
    4) run the wires for the LL
    5) install pitot tube
    6) run pitot tube lines
    7) install magnetometer (if doing electronic flight display)
    8 ) run magnetometer wire
    9) put in flap bellcrank access cover
    10) cover the wing tip LE fairing
    11) install aileron servo
    12) install aileron cable and tie it off
    13) Install the pocket pieces at the strut attach points
    Last Pre-Cover checklist
    1) Check every Ince for sharp edges
    2) Use an air nozzle to clean out all drill chips and other debries
    3) Clean any and all ink off - it WILL bleed through
    4) Safety wire the tank bay rib
    5) Don't drill the landing light trim piece until after cover and paint
    there may be others....if you guys see something I am missing please let me know. I will get a little breakfast and elaborate on the above some.
    Hope this helps
    And a little 15 second teaser video. This is Mark's recently completed Javron Cub on Wip 2100A floats on a lake in Alaska that you can only get to by floatplane.
    Very Blessed.
    Likes Scott A, tedwaltman1 liked this post
  17. #57
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,615
    Folks
    Lets talk about the above list one by one.
    1) Wingtip light mounts......you can order some from Javron or build your own. Here is a link to my other thread on how I built my own mounts.
    https://www.supercub.org/forum/showt...l=1#post598590
    I like to use the Aveo Ultra Daylight lights, but the Javron wingtip mount fits the Powerburst NXT light which is a different shape. Soooo.....
    if you order the mount from Javron make sure you buy the right light. I think you can get both from Javron and thus ensure they are matched.
    2) Wires - you can run the wires for the wingtip lights shielded or not. I (and others) have used non shielded and had no problems. Shielded is heavier, but it does bundle nice. Also you will need 4 wires if you want to make all your strobes go off at the same time. I have not been able to find ANY data that indicates that synchronized strobes enhance visibility. My own personal observation makes me believe the unsynchronized strobes are more visible. So I just run three wires. Saves weight too.
    I like to use these grommets from McMaster Carr for wires, pitot lines etc. They are super light and easy to install. They come in several sizes.
    The part number is 5269T12 or 5269T14 so you can look them up. Pretty simple. Drill the hole with a step drill, clean up the edges, and snap the grommet in.
    Line Product Ordered Shipped Balance Price
    1 5269T12 Locking Grommet for 5/16" Hole Diameter, 1/4" ID, Black, Packs of 100 1Pack 1 0 7.32Per Pack
    2 5269T14 Locking Grommet for 1/2" Hole Diameter and 1/32" to 1/16" Material Thickness, Black, Packs of 100 1Pack 1
    3) Landing lights - We looked at a number of options and companies and felt like the Baha Designs Squadron Pro was still the best option.
    https://www.bajadesigns.com/products...ary-light-pod/
    There are brighter lights out there but you also need to look at the amp draw. I do not want to have to put a 60 amp alternator on the front of the engine just to drive the lights. Also, some of the newer high intensity lights will auto reduce as they heat up. The companies don't like to admit this, but it happens and is an issue. You pay for a 60,000 lumen light but you may only be getting 30,000 lumen most of the time. Just a heads up for you to research and consider.
    Brad did a little science experiment to see how large the LL lens needed to be. The lens Jay sells is about 17 inches wide. But the angle the light comes out at does not require this wide an opening. So we were able to cut down the size and width of the LL cavity and lens thus saving weight. Our lens is now about 10" wide.
    A die grinder and a cut off wheel will work great for cutting the LE out. Go slow. and remember to drill a hole at each corner and cut into the hole.
    You can see the corner holes here. Square corners crack so you want to have a nice radius on each corner.
    The finished cut out.
    The Squadron Pro light
    Showing the size of the cut out
    Then we will rivet in the channels that hold the lens in place. This is all pretty thin material so you will be dimpling the holes and using flush rivets.
    When you are done the lens should lay in pretty close to flush with the leading edge. It is not proud of the LE, and it does not sit "on" the LE.
    After you trim (cut to fit) the lens be sure to sand the edges nice and smooth to reduce stress risers and prevent cracking. Get rid of all your "tool marks".
    Next we need to put in nut plates to hold the trip piece that covers the lens edges. You can see some just laying on top as we talk about where to locate them. You need about 4 across the top and bottom edges and three along the sides.
    Here you can see the trim piece and the screw locations.
    With the landing light installed. You will have to make a mount for the light. Use a piece of .025 and bend a couple of edges to make it stiffer (or you can rivet a 90* piece to make it stiffer, you can see my rivets in the photo) then cut it out so there is a tab on each corner, then pop rivet those tabs to the ribs on either side of the LL bay. If you look closely you can see the clecos where the tabs are going to be riveted to the ribs.
    Lots of ways to do all this, but this is just one idea. I think Javron also sells a light install kit but I think it is heavier than this method.
    Hope this helps
    Very Blessed.
  18. #58
    Mar 2022
    1
    Quote Originally Posted by thaefeli View Post
    Herman,
    Bill,
    Tom
    I'll be getting mine shorty after yours. I'd love to chat and get progress updates as you move along.
  19. #59
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,615
    I edited and added to the post above
    4) Install landing light wires. Pretty straight forward. Two wires....red and black. 18 gauge will be fine for LED lights. I prefer to run these through separate grommets than the wingtip wires. Makes it easier if you have to replace a wire. When you get to the tank bay you may want to run the wires in a plastic tube/sleeve and I use the screws holding the LE on to hold a couple of clips (made from .020) to hold the wires in place. It may also help to separate the magnetometer and other wires as much as possible. In this photo you can see the magnetometer bundle (black sleeved wire) running at the top of the spar cap and the other wires, and pitot lines, at the bottom of the cap (wing is upside down). Eventually they all run together down the door post so you can't separate them all the way, but as much as possible.....
ID:	62490We will add some more holders to keep the wires in place.
    5) Install pitot tube
    You have a couple of options. The lightest and simplest is to have Jay weld a tube into the jury strut. Light and simple. This is what I did.
    But if you are going with a glass set up and you want AOA info you may have to run two lines and install the fancy Garmin pitot tube. The advantage is "AOA is EVERYTHING" and that is how an airplane flies. So having an AOA indicator can be very helpful. The Garmin install manual has instructions on where to mount the pitot tube. You may also want to heat it if you seriously.... PLAN..... to fly IFR. It does add a pound or so more weight if you want the AOA function.
    I am assisting/mentoring Brad with his build. This is HIS airplane built to HIS mission. He wanted AOA. Thus we are doing the AOA pitot probe.
    Build YOUR perfect airplane to fit your mission.
    Brad riveted the mount to the rib just outside the jury strut, and screwed it to the spar cap.
    bend the edges down for extra strength.
    6) Run the pitot lines. I don't have a picture for this but I will try to describe it. With the Garmin mount you will attach the pitot lines after covering and paint, so they will be sticking out during the covering and painting part. Once attached the lines will need to be pulled into the wing. I recommend you test this before cover and determine how far to pull these lines in (from the wing root) and then mark the line. If you pull it too hard or too far you could kink the lines. So by marking the line you will know just how far to pull it to get a nice curve in the line without getting a kink in it.
    7) Install the magnetometer.
    If you are going glass you will need to mount the mag before covering the wing. Garmin has a mount but Jay also set one up in CAD and it fits very nice. This will be mounted into the spar web. I DO NOT like drilling into the spar web and recommend you do it as little as possible. But if you must be sure the holes you make are round and clean. A drill bit does not make a round or clean hole. Drill undersize and ream up. Now you have a round hole. Smooth the edges as much as possible to reduce stress risers. Pop rivet it in.
    Very Blessed.
  20. #60
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,615
    8 ) Run the magnetometer wires
    We got this wire bundle remade from Stein with the ends already set up. The downside is you can't feed it through a small hole. So, Brad made tabs with a slit, then riveted those to the ribs. Then installed the grommets. Looks like this. Pretty clever way to do it.
    You can see the slit in the tab. This allows you to slip the wire in rather than feed it in. You can also see the little triangle tab riveted in.
    9) Flap Bellcrank access cover
    You can install the standard rectangular access reinforcement and cover per Piper drawings, that is what I did on my Cub, or you can make it a little larger by just putting some nut plates in the ribs. Larger is better and adds little if any weight. I like better as long as it does not add weight.
    You will have to make a little C shaped piece from .020 or .025 and screw it to the spar cap (use existing screws) to get a level point for the front of the access cover plate. Install some nut plates and poof you are done. Don't forget to clean the ink off that little C shape you screwed in otherwise the ink will bleed through the fabric when you cover and make a mess.
    10) Optional......,Install wingtip fairings to smooth out the covering.
    The wingtips on a square tip wing can be covered as is but the fabric will have some pretty sharp sags and perhaps even a wrinkle. If you want to make it a little nicer you can install some little fairings to make the fabric hold its shape a little better. These are made from .016 material and pop riveted in place. You will not be able to bend the entire edge down because it is going to assume close to a compound curve shape so just cut and leave little tabs (reference the wingtip light mounts we fabricated) if you are struggling to visualize what I am trying to say.
    This is a bottom fairing. You can do a top as well but the bottom is the more critical of the two.
    I am finding it much more difficult to do as "How to" thread when I am not actually doing the work. Arggggggg
    More to follow
    11) Install Aileron Autopilot servo
    Part of Brads mission involves a fair amount of cross country flying. In that respect an auto pilot can be quite helpful. The way we have configured the fuselage of his 4S there is not an easy place to install the aileron servo in the fuselage or directly to the torque tube as in some other applications. Soooo......we have installed it in the wing. I don't have a picture of the servo install but Brad sent me this little video. Brad made a mount plate that attaches to the upper and lower spar caps and does not attach to the spar web.
    https://youtube.com/shorts/fHZ0E_fBnvQ?feature=share
    Hope this helps
    Very Blessed.
    Thanks rmac, tedwaltman1 thanked for this post
    Likes Scott A liked this post
  21. #61
    4,637
    I'd like to add a couple of things about the magnetometer wiring. If you are running LED nav/strobe lights, those lights PROBABLY will not draw enough to effect the readings from the magnetometer. But, if you run pitot heat and/or landing lights (especially incandescant lamps), there is a good chance the current draw from these will change the magnetometer readings. To prevent this from happening, keep the magnetometer wires separate from all other wiring. As Bill pointed out, there are places like the windshield post where the wiring simply cannot be spaced apart. So keep the wiring separated when you can and in the tight spaces just don't tie the the mag wires into the bundle with other wiring. Also, I've had good luck just 'gluing' the wires into place on the spar using RTV. Tape wires into place and add dabs of RTV. Pull the tape once the RTV sets up. Still allows you to pull the wires out if needed, in the future.
    Nothing wrong with the mounting bracket in the pics, but I agree with Bill, I don't like extra holes in the spar. I prefer using a bracket between the ribs. Which ever way you decide, make sure you use the correct hardware! It should not need to be said but DO NOT use ferrous hardware. Garmin instructions even say to not use magnetic screwdrivers or electric drill motors when installing or maintaining these items. While Garmin says stainless screws are ok, I still use brass screws nuts and washers.
  22. #62
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,615
    12) Install aileron balance cable
    The aileron cable that goes through the tank bay and through the pulleys in the wing needs to be threaded in before you cover. A couple of feet will hang out of the root area, and the other end needs to be tied off in the wing. This cable end will be fished out via a wing inspection hole and will come out the bottom fabric and will connect to the bottom side of the aileron horn. (the other cable runs up the strut, through the wing, and comes out on top and connects to the top side of the horn.)
    Attachment 62526
    I just taped it off to the drag/anti drag wire. After cover and paint it can be fished out and pulled through the fabric and then the end turnbuckle swaged on to fit.
    Jay has created these little metal pieces that help build a pocket for the strut ends to go up into. When you install the struts on a covered wing the end of the strut will protrude up into the fabric. It can be a messy install. Jay has made these little fairing brackets that create a pocket for that strut end to go into.
    Attachment 62527
    This goes on the front strut. It is just laying in place. Tuck the ends under the LE and put a rivet in each end before cover.
    Attachment 62528
    This piece goes on the rear strut attach point. It will be installed after cover and then reinforced and cleaned up with tapes and or doilies.
    Attachment 62529
    An over view showing both pieces laying in place to give you location reference. These pockets need to be pretty deep. Otherwise you are pressing hard into the fabric and forcing it to give. You may end up having to split the fabric if you do not create these pockets. Then you have a substandard ugly install.
    That should be most everything (I hope ) that needs to be done to the wings before covering.
    Hope this helps
    Very Blessed.
  23. #63
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,615
    I don't know why it is giving me the "attachment" issue on photos. I will try to get that fixed.
    Lets talk about the fuselage.
    I spent a couple of days in Jays shop going over the fuselage and making changes. I'm sure some of these will be incorporated into future kits and others will remain as possible options, depending on how you want the fuselage configured to suit your particular "Build for 90% of your flying" axiom.
    I did have Jay weld in the mounts for lead to adjust the CG
    After talking with the structural engineer we determined we could adjust the dogleg and increase the size of the baggage door. It will go from about 24 x 25 to 27x27.
    The prototype fuselage had rudder pedals and toe brakes suspended from the upper longerons. It does make for a clean floor. Our objective was to make this as much like a Superb as possible so this assembly will be put under the floor and the rudder pedals will look like a stock cub and it will have heal brakes.
    These top two tubes will be relocated under the floor to create something more akin to a stock superb. We will also run the rudder cables under the floor so they will have a straighter run and also that will get them completely out of the baggage area.
    Very Blessed.
    Thanks spinner2 thanked for this post
    Likes Buschpilot liked this post
  1. Javron Cub Building for Dummies
    By Sam D in forum Member Projects in Progress
    Last Post: 08-26-2022, 07:47 PM
  2. Building a Javron Cub
    Last Post: 06-05-2022, 08:15 AM
  3. Ron Building Javron Cub 1
  4. Who is building a Javron Cub?
