Folks
Lets talk about the above list one by one.
1) Wingtip light mounts......you can order some from Javron or build your own. Here is a link to my other thread on how I built my own mounts.
https://www.supercub.org/forum/show...g-a-Javron-Cub&p=598590&viewfull=1#post598590
I like to use the Aveo Ultra Daylight lights, but the Javron wingtip mount fits the Powerburst NXT light which is a different shape. Soooo.....
if you order the mount from Javron make sure you buy the right light. I think you can get both from Javron and thus ensure they are matched.
2) Wires - you can run the wires for the wingtip lights shielded or not. I (and others) have used non shielded and had no problems. Shielded is heavier, but it does bundle nice. Also you will need 4 wires if you want to make all your strobes go off at the same time. I have not been able to find ANY data that indicates that synchronized strobes enhance visibility. My own personal observation makes me believe the unsynchronized strobes are more visible. So I just run three wires. Saves weight too.
I like to use these grommets from McMaster Carr for wires, pitot lines etc. They are super light and easy to install. They come in several sizes.
The part number is 5269T12 or 5269T14 so you can look them up. Pretty simple. Drill the hole with a step drill, clean up the edges, and snap the grommet in.
Line | | Product | Ordered | Shipped | Balance | Price | |
1 | 5269T12 | Locking Grommet for 5/16" Hole Diameter, 1/4" ID, Black, Packs of 100 | 1Pack | 1 | 0 | 7.32Per Pack | | 2 | 5269T14 | Locking Grommet for 1/2" Hole Diameter and 1/32" to 1/16" Material Thickness, Black, Packs of 100 | 1Pack | 1 | | | |
3) Landing lights - We looked at a number of options and companies and felt like the Baha Designs Squadron Pro was still the best option.
https://www.bajadesigns.com/products/squadron-pro-black-flush-mount-led-auxiliary-light-pod/
There are brighter lights out there but you also need to look at the amp draw. I do not want to have to put a 60 amp alternator on the front of the engine just to drive the lights. Also, some of the newer high intensity lights will auto reduce as they heat up. The companies don't like to admit this, but it happens and is an issue. You pay for a 60,000 lumen light but you may only be getting 30,000 lumen most of the time. Just a heads up for you to research and consider.
Brad did a little science experiment to see how large the LL lens needed to be. The lens Jay sells is about 17 inches wide. But the angle the light comes out at does not require this wide an opening. So we were able to cut down the size and width of the LL cavity and lens thus saving weight. Our lens is now about 10" wide.
A die grinder and a cut off wheel will work great for cutting the LE out. Go slow. and remember to drill a hole at each corner and cut into the hole.
You can see the corner holes here. Square corners crack so you want to have a nice radius on each corner.
The finished cut out.
The Squadron Pro light
Showing the size of the cut out
Then we will rivet in the channels that hold the lens in place. This is all pretty thin material so you will be dimpling the holes and using flush rivets.
When you are done the lens should lay in pretty close to flush with the leading edge. It is not proud of the LE, and it does not sit "on" the LE.
After you trim (cut to fit) the lens be sure to sand the edges nice and smooth to reduce stress risers and prevent cracking. Get rid of all your "tool marks".
Next we need to put in nut plates to hold the trip piece that covers the lens edges. You can see some just laying on top as we talk about where to locate them. You need about 4 across the top and bottom edges and three along the sides.
Here you can see the trim piece and the screw locations.
With the landing light installed. You will have to make a mount for the light. Use a piece of .025 and bend a couple of edges to make it stiffer (or you can rivet a 90* piece to make it stiffer, you can see my rivets in the photo) then cut it out so there is a tab on each corner, then pop rivet those tabs to the ribs on either side of the LL bay. If you look closely you can see the clecos where the tabs are going to be riveted to the ribs.
Lots of ways to do all this, but this is just one idea. I think Javron also sells a light install kit but I think it is heavier than this method.
Hope this helps
