It depends. On a plastic can or bag, a static charge CAN build up on the entire surface of the container. Just putting that container in contact with the airframe only equalizes the charge between the plane and the portion of the container that’s in contact with the airframe. So, there can still be significant static charge on the rest of that container, which COULD provide an unpleasant surprise. What are the odds? Pretty low. But not zero.
I’ve fueled from plastic cans, but I never assume there’s no risk.
Let us know how all these jiggle hoses, pumps, bags, etc work in cold weather. Real cold weather.
Jim
Jim
Eskflyer, I too am going to order that pump you suggested. Looks good. I didn't quite understand what you were doing with the cap so send me pictures so I can duplicate. And think of this; it's 2 am in the morning and you're out in the bush or backcountry and your parked next to a guy with Dodge's 30 gallon tanks. You need gas and he has plenty. With a little extra hose you can get all you need and not even have to have carried those troublesome gas bags and he'll never know as when you have 60 gallons of gas who ever checks what they have cause they have plenty.
OMG , I would never put "DODGE" fuel in my airplane , dont ya know how dangerous that is , You must use Ford and on the one off Chevy fuel but never DODGE.
A few months ago, I was standing on an 8.50 tire and fell backwards, sustaining 11 fractured ribs, 5 fractured vertebrae, and a punctured lung. It still hurts.As I mature it takes 2-3 trips to fill a wing tank it used to take just one. I got all day to do a day's work.
I’m jittery about those alligator connectors. Why not use battery clamps?
Knowing me, I’d tug on the hose and bump the connection, and sparks would fly.
ill use get a cap and install the fitting thru the cap just like the pour spout is for our fuel bags will leave the cap in the fuel box with pump when done.
https://www.amazon.com/dp/B06XD7HG63/ref=emc_b_5_i?th=1
Doh, I'm a goober... I thought you were going through a cap on the other side.Yes, I thought I would not have to point out the obvious , but the cap is just to secure the line hose going into the fuel bag not make it airtight.
GEEEEEEESH, the question has been answered and you guys that cant think outside the box even a little bit are so far out there. I have been filling gas cans since about 1973. OMG I was abused by my parents for teaching me how to properly fill gas cans plastic metal glass ect, vehicles airplanes since I was 7. I am sorry for those that have had an incident and injured. but dammit guys if you want to be truly safe go crawl under 6' of dirt and call it done. Im going to continue the way we have and enjoy life and continue to fly and fill my sleds my motorcycle my airplane my side x side my chainsaw and everything else with the ohhhh so dangerous plastic fuel jugs / fuel bags / my approved for gasoline bought on amazon made in America fuel pump kit. loosen up be safe and go fly.
just my 2 cents and with inflation that aint worth #%it
JP
Everyone should watch how fuel fumes flow (an IR scope/camera will show it) if they come out from being disturbed, they then spill out and run down to the ground and in this case possibly flowing over the battery. This one and the larger transfer tank/pump previously shown in this thread would be much safer with the battery mounted high and away or better yet remote. Oh and loose the alligator clips, use a hard clamps with a high mounted switch to get the arcing devise out of harms way.I have a friend that built this with a harbor freight transfer pump. He says he likes it, but it's a fairly recent build.
I didn't ask if I could post his photo, so I removed the N number.
https://www.harborfreight.com/12-volt-diesel-transfer-pump-66784.html
Sent from my SM-N975U using Tapatalk
Everyone should watch how fuel fumes flow (an IR scope/camera will show it) if they come out from being disturbed, they then spill out and run down to the ground and in this case possibly flowing over the battery. This one and the larger transfer tank/pump previously shown in this thread would be much safer with the battery mounted high and away or better yet remote. Oh and loose the alligator clips, use a hard clamps with a high mounted switch to0 get the arcing devise out of harms way.
