Results 1 to 17 of 17
Thread: Insulation and Soundproofing
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    355
    Does anyone have any suggestions on a material for insulation and soundproofing a new/ rebuilt bootcowl? It’s a certified-18.
    PA-12 N418BS
    cubdrvr's Avatar
    Jan 2002
    1,347
    It's been 20 yrs. and I can't give you a name but I used an aluminum backed high density green foam.....about 1/4" thick.....came in sheets about 3' wide.
    self sticking ( and I mean self sticking......once placed it's not coming off)
    Really helps with noise...somewhat warmer I think .... and no oil canning of the boot cowl.
    I'd do it again.
    Thanks Farmboy thanked for this post
    Likes Hardtailjohn, Paul Heinrich liked this post
    Jan 2021
    Nevada
    80
    I once knew a guy who put rubber on his boot cowl in his 172. Man that thing was quiet! The rubber itself was between an eighth and a quarter inch thick (estimate) and he just used some spray on contact cement to put it on there. It made a big difference.
    12,052
    Selkirk Aviation in Idaho sells soundproofing and insulating foam rubber for aircraft use. I think they have 1/2 and 1/4 inch thick.
    Likes Hardtailjohn, DENNY, Delta Cub liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    896
    Dynamat is used for car interiors and is very easily available. My brother has that in his Taylorcraft and it works very well to quiet it down inside.
    Jan 2016
    Eagle River, AK
    211
    Anyone know what that black gunk was that Piper used back in the day?
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    279
    If its the same stuff I used for the engine box on my side x side, yes it works well but damn is it heavy! Not sure that is what I would be using in the plane.
    4,444
    I like the Lizard Skin stuff for cars. Has anyone weighed a panel coated with this stuff? I'd like to try it on the next firewall/boot cowl.
    Likes mixer liked this post
    Dec 2016
    Canyon, tx
    981
    Noise canceling headset
    Likes stewartb, RaisedByWolves liked this post
    4,444
    What?
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,103
    What you're referring to is I believe, is the noise reduction technique of taking a quality ANR headset, or several, and running it through a table or band saw with a fine tooth blade, and then taking the resultant 1/4" slices and gluing them to the firewall. We know how well the headsets work..., this just gets them working right up on the firewall where the noise originates.
    Likes Gordon Misch, Crash, Jr., phdigger123 liked this post
    stewartb's Avatar
    Wolf Lake, AK
    7,151
    I have a thin foam layer on the firewall for heat. Zero noise concerns so nada on the boot or anywhere else. No problem. My A20 helmet comm works perfectly. The same is true in the 180, but I will say Zulu 3s are superior to 2s, but both are pretty damn good. We’ve come a very long way in the last 25 years!
    Likes courierguy, Crash, Jr. liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    896
    Imagine if the FAA had to approve new aviation headsets like they do aircraft mods. We would be using ear plugs and some cans connected with string!
    Likes bubb2, AZinAK liked this post
    21,793
    Quote Originally Posted by bubb2 View Post
    Automotive undercoating.
    Thanks bubb2 thanked for this post
    Nov 2015
    Fairbanks, AK
    128
    Aircraft Spruce carry’s various thicknesses and types of soundmat, some self adhering, some you have to use contact cement. There’s at least a couple of 3M glues available in spray cans that work real well and are a snap to apply. Better than a can and a brush by far.
    Spruce even offers a FREE booklet on “Soundproofing Your Light Aircraft” for what it’s worth. There are some good tips in that booklet.
    Cheers, Oz
    Likes Litecub liked this post
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY & Middlebury, VT
    2,855
    Checking in - any updates or additional recommendations on insulation/soundproofing material?
    - light, non-moisture holding, non-corrosive, non-deterioration
    Dec 2009
    Michigan
    159
    It would be cool to gather some data on sound reduction.....like measure the sound intensity before and after each product and area was modified. A chart with sound reduction, weight gain, and cost would be good data. I'm building right now....maybe some day unless someone beats me to it.
    Likes Farmboy liked this post
  1. Insulation
    By Grizzley in forum Super Cub Sick Bay
    Last Post: 12-05-2009, 06:45 PM
  2. Insulation
    By S2D in forum Tips and Tricks
    Last Post: 01-05-2005, 02:05 PM
