Results 1 to 18 of 18
Thread: Twisted elevator or stabilizer on Super cub? Help!
    Sep 2021
    5
    I noticed that on my super cub that the elevators are not even on both sides while in neutral still position. I am trying to figure out what is bent. I checked where the elevators bolt together and everything looks fine there yet. The right elevator is the one that is lower. Any info would be appreciated on what to do to find out what is bent. I also placed a straight edge on stabilizer and on elevator. When everything is flush the elevators are centered in accordance with the corresponding stabilizer if that makes any sense.
ID:	59389   Click image for larger version.
ID:	59390   Click image for larger version.
ID:	59391   Click image for larger version.
ID:	59392   Click image for larger version.
    Dec 2018
    Rangely, Co
    87
    I had that on my Stinson, which had been repaired. Seemed it was the elevator was warped slightly. Sorry I can’t help with the best way to check it. I would lean towards using a laser level though.
    May 2017
    1,373
    Normally addressed before cover, not sure if you can bend things to line up after it's covered.
    Nov 2019
    Kalispell, Montana
    55
    In about 1970 when I was in the Navy, I bought a new Maule and went to Moultrie, Georgia, to pick it up. Before B.D. Maule gave me a demo ride (off the ramp!), I pointed out to him that the elevators didn’t line up with the stabilizers equally. He grabbed the right stabilizer and bent it until both sides were even!
    stewartb's Avatar
    Wolf Lake, AK
    7,155
    Twisted or not indexed properly? It looks like the latter.
    Apr 2009
    AK
    274
    Tons of them flying around up here that way. Either bend it straight or run it and forget about it.
    Likes wireweinie, supercrow liked this post
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    1,000
    Pretty standard right after you bump the tail into a frozen snow bank
    P.S. Standard bush fix: Is cut a 2x4 the right length, to fit under the horizontal rear tube and hanger floor, THEN bent the elevator to match up..........
    Good Luck
    E
    Likes tedwaltman1, DENNY, Colorguns liked this post
    9,782
    Those are the days Mom forgot to tell us about.
    Likes TurboBeaver, Colorguns liked this post
    supercrow's Avatar
    Dec 2008
    610
    In most cases I have had good results with a heat gun (carefully) to remove any fabric wrinkles you end up with.
    Likes DENNY liked this post
    Sep 2021
    5
    Thanks for the input guys. I assumed that the correct way to fix it was to persuade it back into where it should be.
    12,000
    Quote Originally Posted by Spida4930 View Post
    Before you start persuading it, check the stabilizers for alignment. It could be a little of both elevators and stabilizer.
    behindpropellers's Avatar
    NE Ohio
    7,037
    I really dislike the idea of trying to twist and force it. Who knows how much corrosion in in your elevators and horizontal stab that may yield when you are twisting. I have seen the same on several cubs. I wonder if the jig is incorrect somewhere that aligns the horn with the elevator.
    12,000
    Wouldn't now be a good time to find any corrosion? ................... on the ground!
    NE Ohio
    7,037
    I was thinking the opposite...they bend and break it and do not find it until something bad happens...
    11,174
    That's why they give you 2 of them ;- )
    12,000
    I hear you. However, when in the process of twisting, the person doing the twisting ought to be able to feel a weak tube fracturing. The level of the resistance should be felt.
    21,812
    From memory there have been a few threads on the same subject over the years. My Dad built Kitfox and noticed the same thing. They told him it was suppose to be that way to put opposing positive pressure on the elevators. We rivet a small bulb section cut off a bulbed angle to each side of the Hawker SeaFury when we put the R3350 engine on it. Nelson told me it kept the rudder from hunting. I have seen plenty of Cubs this way and they flew just fine.
    2,775
    If it flys fine it might be best left alone (the enemy of good is better). Depending on pilots sill level the plane may need a major recover in the next few years and it can be fixed at that time. At least that is what my IA said to me when I wanted to to fix some paint issues on my plane!
  1. Stabilizer/Elevator rigging
    By giangab in forum Tips and Tricks
    Last Post: 10-30-2019, 08:08 PM
  2. Replies: 1
    Last Post: 06-20-2017, 12:30 AM
  3. For Sale- Airframes Inc Elevator, Stabilizer & Rudder Ri
    By RYAN_WINGS in forum Cafe Supercub
    Last Post: 09-28-2005, 10:25 AM
