flyanozira
SPONSOR
Phoenix, Az
A friend bought a very nice looking SC recently. the rebuilder put a lot of experimental parts on it, that have been removed and replaced with certified. (waste of time IMHO) But the main issue is the engine and mount. A wide deck 160 hp 320 was installed using the STC from CC for this application. But there is no clearance between the plug for the screen and the engine mount. So far we've determined the lord mounts installed are not correct, they are a smaller diameter than what the STC calls for, which leads me to believe the engine mount is not correct as the spec'd lord mount don't fit the engine mount. There is no p/n on the mount that we can find.
I know that someone out here knows what the issue is...any help appreciated.
