Looking for the control stick tubing size and wall thickness. Thanks
http://supercubproject.com/drawings/pdfs/A3290674.pdf
Drawing 40231
Looks to be 1.14" X 0.035"
Thanks Grant. Anyone know where 1.14" x .035" tubing is available?
Closest would be 1-9/64" tubing. Kind of an odd size. The drawing I believe is for a J3 not a PA-18 although the sticks aren't very different. I was under the impression that a more common size like 1-3/16" was used for cub sticks. Where would you get 1.14" OD tubing?
Quite a few wooden broom stick handles on Chinese Walmart brooms seem to have the perfect diameter.![]()
And they have a pleasingly rounded end for your palm when cut to your preferred length.
I, of course, have never used one of them for such.![]()
It is an odd dimension. Have run into that before.
I think Jay at Javron should have it. Owner produced part.
Now the real question: long stick or short stick? Straight stick or curved stick?
Kinda sounds like a Dr. Seuss book
From the Northland drawings. Interesting that they called for aluminum or steel. Note the section to be expanded in order to fit over the stub on the torque tube.
Tube diameter is determined by what you need to fit into the socket or stub in the pivot. My exp Cub sticks are 1”.
Tons of previous threads on this subject.
Can you please provide a reference to the governing regulation. Your interpretation seems to be more restrictive than AC 20-62E para 4 (n).
"n. Owner/Operator Produced Part. Parts that were produced by an owner/operator for installation on their own aircraft (i.e., by a certificated air carrier). An owner/operator is considered a producer of a part, if the owner participated in controlling the design, manufacture, or quality of the part. Participating in the design of the part can include supervising the manufacture of the part or providing the manufacturer with the following: the design data, the materials with which to make the part, the fabrication processes, assembly methods, or the quality control (QC) procedures."
No mention of approved drawings here.
When I was in partnership on an Aeronca Chief we produced brake pads with no other reference than the worn out originals.
"(2) Parts produced by an owner or operator for maintaining or altering their own productand which are shown to conform to FAA-approved data"
Page 2 https://www.faa.gov/documentLibrary/...-62E_CHG_1.pdf
That paragraph appears to me to provide one means of compliance but not the only means of compliance. It does not define "owner produced parts".
I found multiple references to owner produced parts that do not reference any requirement for FAA approved data. Here is one -
https://www.cessnaflyer.org/maintena...lications.html
Best piece written about owner produced parts by a Fed that was one of the good guys. https://150cessna.tripod.com/obrieno...madeparts.html
All the cheap owners that want to buy parts from Javron and get them signed off as an owner produced part, I hope those airplanes never darken my hangar door.
Will RogersRaisedByWolves liked this post
It is in the first part of the definition of “Airworthy” must meet type design or properly altered condition, and be in condition for safe operation.
If it doesn’t meet the drawings, then it doesn’t meet type design, so the next issue, has it been “properly altered”? If it is a major alteration, it needs approved data. For the definitions of major alteration and minor alteration see 14 CFR 1.1. Now, next issue, unless the act of removal and installation is defined as preventive maintenance, you need an A&P to install that owner produced part!
Maybe Mauleguy will chime in and give us an idea of what material to buy.
