Page 2 of 2 FirstFirst 12
Results 41 to 70 of 70
Thread: Super Cyclone
  1. #41
    stewartb's Avatar
    Wolf Lake, AK
    7,306
    Mike and I had no info and no idea how to install my AP in the Cub. It required creativity. I like the drive rod in rancher’s wing. That could have worked in the Cub. We all get to learn from threads like this one. It’s the best part of this site.
    Likes jrussl liked this post
  2. #42
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,124
    Steve Pierce wrote
    Jim Younkin drew out how to install his autopilot in my Dad's Clipper on a napkin.
    Here is a picture of me with Jim and his brother Bill when I spent the winter of 1996/7 learning and helping. My Dad was good friends with their other brother Bob. The Mullicoupe had bungee cords that were like rope wrapped around numerous times and tied off. He was fretting about how to get them tight and said "this is Arkansas so it has to be simple". I actually came up with an idea using a vise grip with some split tubing welded on the jaws. He was skeptical----I said let's try-----when it worked good, he ran to the phone and called Bud Dake. I was technically the pilot one time before he got his medical back.
ID:	59434Click image for larger version.
    Likes skywagon8a, Farmboy, Steve Pierce liked this post
  3. #43
    Dec 2017
    NE
    81
ID:	59574Click image for larger version.
    Back riveted on the stringers to the outer skin and the intermediate skin that I made and hung them on the bottom of the wing. One of the guys that helps me out on the ranch and helped me rivet on the top skins ran the air gun for riveting on the rest of the wing skins. After bucking some hard to reach rivets in the intermediate skin and not being able to reach a couple rivets, out came the fly cutter and a new inspection hole appeared. Viola, bucking rivets mage easier!
    Back riveted on hat channels to the fuel tank bay skin. I used blue tape because that is what I had, works ok but the tape sticks to some of the rivet heads after setting the rivets. Hung the skin onto the wing and bucked more rivets.
ID:	59576   Click image for larger version.
ID:	59577   Click image for larger version.
  4. #44
    Dec 2017
    NE
    81
    Welded up the fresh air vent for this wing, I tried to bend this tubing in a pipe bender but it is rigid stuff and just broke, so I cut the angles and tig welded the elbows, they attach to the leading edge with screws into nut plates.
    Had to drill out the flap and airleron belcranks. The original owner drilled them out and put in brass bushings. However Cessna used a pipe in the belcranks so the bolt through the brackets and the pipe are tight and the belcranks turn on the pipe. Without the pipe the bolt will come loose and where out the brackets. So I drilled them out then bored them until the pipes just fit, much better!
ID:	59579   Click image for larger version.
ID:	59580   Click image for larger version.
  5. #45
    Dec 2017
    NE
    81
ID:	59582Click image for larger version.
ID:	59583Click image for larger version.
ID:	59584Click image for larger version.
ID:	59585Click image for larger version.
ID:	59586Click image for larger version.
    The first pic is of the intermediate skin with 3 inspection holes in it instead of 2. Less acrobatics involved to buck rivets.
    Then my high tech tools for bucking rivets. Thinking of buying a roller cart for holding rivets and bucking bars and light and mirror at arms length instead of the little stool that isnít big enough. We used the flush rivet set on the right on this wing and we didnít get as much distortion at the ribs where we hammered the rivets. I thing this wing looks better.
    I am holding the autopilot servo and bracket in the inspection whole where it will go. Thought I had better make sure I could get them in the wing before I riveted the skin on.
    The four holes are in the bottom of the wing, and the bolts go through the skin and the bracket into the servo bracket with nut plates on it. The wing bracket is riveted to the airleron spar and the rear main spar and is made of .050. I bent a 90 in the bracket for strength, just bent it on the wrong side, made riveting more difficult and installing the servo tougher. I donít remember anybody saying this would be easy!
  6. #46
    brown bear's Avatar
    Feb 2004
    emporia ks
    613
    I know their high priced but I love my tungsten bucking bars , I have only two , a 1.5 " x 2 x5/8" with a angle end and a 1x5/8x4"
    I find myself using these most of the time and all my regular bars only rarely
    https://www.yardstore.com/riveting/b...n-bucking-bars
    Doug
    Likes Steve Pierce, wireweinie, 180Marty liked this post
  7. #47
    Dec 2017
    NE
    81
ID:	59756Click image for larger version.
ID:	59757Click image for larger version.
ID:	59758Click image for larger version.
ID:	59759Click image for larger version.
ID:	59760Click image for larger version.
ID:	59761Click image for larger version.
    Finished up riveting the right wing, switched wings in the jig. Put the flap in the right wing and the flap has full travel in the flap, tracks. The only negative is the flap doesnít line up with the rib where the airleron attaches. I think the only way to fix this is to drill all the skins off and realign the top of the flap tracks with the rib where the airleron attaches.
    Next thing was to put in the flap gap seal. I aligned it with the flap and then drilled the seal and the skins. Deburred the holes and countersinked the seal and dimpled the lower skin. Put the seal in and riveted.
  8. #48
    1,400
    Quote Originally Posted by 180Marty View Post
    The Mullicoupes are my favorite airplane short of Mr. Mulligan. Got the chance to fly Budís Mullicoupe, now owned by Mark Holliday a couple years back. Jim had a True Track in his Pacer. Heíd pull it out at annual time, and back in after the inspection was done. He helped me a lot when I had my Howard. Loosing Bud when the 110 crashed was a real blow. Then Jim passing away a couple years ago was another great loss to the aviation community.
    Likes 180Marty, silflexer, Steve Pierce liked this post
  9. #49
    Mar 2010
    Southeast Michigan
    11
    These aircraft are absolutely beautiful. It is good to see this alive and well. I recall when these were introduced to the market and realized one of these could never happen for me. Dig in for the long run and make it happen.
    Best of luck!
  10. #50
    Dec 2017
    NE
    81
ID:	60367Click image for larger version.
ID:	60368Click image for larger version.
ID:	60369Click image for larger version.
    With the flap installed it was on to the airleron. The guys ahead of me had built the airleron flat so I ordered another skin, but the cyclone skin and the Cessna skin corrigations were not exactly the same. So I spliced the outer 13Ē with the new skin. I built two ribs because with the proper twist the holes didnít line up any more. Cleaned all the parts and primed and started riveting. I didnít go look at the first airleron and didnít put a strength strip in the trailing edge, had quite a time squeezing the rivets in the trailing edge. After several days I realized my mistake, drilled out the rivets and put in the strip and riveted again. The final product looked pretty good. I balanced the first airleron and used 5 1/2 weights in both airlerons. Clecoed onto the wing the airleron balances perfectly. Drilling out rivets seams to be counterproductive , I realize this airplane will not be perfect because it is my first, but I want it as good as I can get!
    The fellow I bought the airleron skin from said to use soft rivets in the weights. He was right. Hard rivets expand in the lead and will not shop head for squat no matter if squeezed or bucked. Hard rivets a difficult to drill out of the lead because they are long and the bit will drift into the lead.
ID:	60371Click image for larger version.
ID:	60372Click image for larger version.
  11. #51
    Dec 2017
    NE
    81
    With the airleron clecoed into place I slid the gap seals into the trailing edge of the wing. I aligned the seals as close to the airleron as possible, clamped, drilled, deburred, dimpled the top, countersunk the seals and finally riveted the gap seals to the wing. The above pictures show the gap seals installed.
    An additional note on riveting the trailing edge of the airleron I used several squeeze clamps while riveting to keep the skins tight to the strength strip. Managed not to get any pictures.
  12. #52
    Dec 2017
    NE
    81
ID:	60527Click image for larger version.
ID:	60528Click image for larger version.
    With with the right wing nearly complete I went to work on the left wing again. I drilled off the tank bay skin and used the digital protractor to align the flap tracks again. I could only get to a half degree of being the same, so I lined up the new skin and went through the process again, drill, debur, countersink, clean, and prime. I also made a new skin for the flap bay because I had drilled the trailing edge for the gap seal and wasnít confident that the holes would line up again after straightening the rear spar. I definitely didnít want to drill all rivets out of the rear spar again to fix the flap bay skin, so I made another and riveted a new skin in this position too.
    I also made different inspection holes in the tank skin near the leading edge. This made riveting easier because we could now reach clear to the rear spar for bucking those couple rivets just at arms length.
    To drill out the rivets I employed the technique of using an undersized bit then breaking the rivets with a punch. This seams to work the best for me as I didnít mess up but one or two holes.
    The backing plate where the airleron pushrod exits the spar did not meet the skin at the trailing edge. So I drill the plate off, made a new one out of the .050 tank skin and riveted back on. Those are the first pull rivets I used and they were bitter sweat. Since then I have drilled off the skin covering the pull rivets to fix a nasty hump and could reach them to buck, but I donít want to drill out dollar rivets!
    Likes FdxLou liked this post
  13. #53
    Dec 2017
    NE
    81
    I have a question for the group. I am going to mount the battery in the boot cowl area similar to the Dakota Cub battery mount for super cubs. With the forward cg Cessna’s have anyway moving the battery forward won’t help. I am looking at the EFII fuel injection and he requires a 5 gallon header tank or the return goes to the main tanks. I was thinking of a header tank under the extended baggage area. 5 gallons would be about 40 pounds and 10 gallon be nearly 80. This would help with cg and add to fuel reserves, 10 gallon would be nearly an hour at an easy cruise. Guidance is appreciated!
  14. #54
    Dec 2017
    NE
    81
ID:	60530Click image for larger version.
ID:	60531Click image for larger version.
    This mirror with the led lights is GREAT!
    Likes brown bear, akavidflyer, Steve Pierce liked this post
  15. #55
    12,174
    Quote Originally Posted by Supercubrancher View Post
    185s are nose heavy when lightly loaded. The battery is placed aft of the cabin for good reason. The folks in Alaska move batteries forward because they find a need to keep them warm in the winter and always carry survival gear for ballast. Overall performance is better when the CG is kept towards the rear. That is a whole other discussion itself.
    Cessna uses a header tank mounted low between the firewall and the control column for the fuel injection positive feed during low fuel steep climb situations and for the fuel return. The fuel injection return can easily be plumbed into the forward fuel line from the right tank in the upper right door post. This is the way it was done on the turbo charged STC in my 185 with Cessna's connection to the header tank capped off.
    While you could install a 10 gallon tank under the extended baggage, depending upon using that fuel for extra cruise time seems as though you could be setting yourself up for a fuel starvation issue should you need a go around while low on fuel. At minimum if this is done, there ought to be an electric pump mounted next to that tank in order to guarantee a positive fuel pressure to the engine during low fuel situations. Just thinking about the negative possibilities gives me bad feelings. When low on fuel in the wing tanks, you would not need the nose very high for the 10 gallon tank not to feed the engine.
    Likes DENNY liked this post
  16. #56
    stewartb's Avatar
    Wolf Lake, AK
    7,306
    5 gallon header? Since when does EFII use a fuel return? No accumulator should be required unless you use Continental injection. I’d call Airflow Performance and have a chat.
    The battery on the firewall doesn’t change CG enough to worry about. My big engine 180J has had an Odyssey on the firewall for almost 25 years. Do I carry a tool bag in back? Yes, but that’s about 10# and that’s all I carry regularly. Well, that and a day pack. No problem. Easily within the envelope. And, it has nothing to do with keeping the battery warm. Odysseys work really well in the cold and most of us use direct conductive preheat so the battery stays cold. It’s about less total weight and short battery cables. And to that, why aren’t you planning on an EarthX? Great batteries!
    PS- Thank you so much for sharing your build. I have great respect for your commitment and hope that plane rocks your world when you get to fly it.
    Thanks Supercubrancher thanked for this post
  17. #57
    2,831
    I am a carb guy so maybe my questions will help. Will this fuel injection system keep the prop turning on gravity alone? The reason I ask is if so the higher the fuel the better!! So you have to figure out what is the high point at high AOA/banking and yanking/slips. I would say none of that is in the extended baggage. Now if the pilot cooler is TOTALLY DEPENDENT on a fuel pump then I would just put it back in the wing from a weight savings/simplicity standpoint. If it will run on gravity than I would say a high tank on the firewall is best. Now to the CG standpoint. Consider the mission and how many times you are going to need or want to be flying with only front seats one pilot and a totally empty interior? No BEER/food/back seats/tools/oil/water/backpack/sleeping bag/shovel/axe/tie down ropes/anchors/ect. When you run out of stuff to stick in the back of the plane you still have a stabilizer to fix things. Now might be a bit more drag, if that bothers you add a case of beer and by the time it is gone you will be happy. Notice I said Beer not a case of oil, If you need to carry extra weight a case of beer or better yet the hard stuff will fix soooo many problems on the road. Do build the fuel system so an add on tank is easy. DENNY
    Likes FdxLou, supercrow, dwm liked this post
  18. #58
    stewartb's Avatar
    Wolf Lake, AK
    7,306
    No FI system I know can operate on gravity.
    The header tank comment got me to read the EFII manual. 5 gallon capacity is to manage heat. I didn’t know EFII required a fuel return. That scratches my interest in adding it to my engine. I guess a guy needs to balance performance features with installation requirements. That said I’d suggest a conversation with Airflow Performance about mechanical FI
    would be worthwhile.
    https://flyefii.com/media/System32-I...l-rev-6-19.pdf
    SDS systems also require a return line. Their system uses main tanks to feed a surge tank that supplies the EFI. Interesting reading.
    http://www.sdsefi.com/em5manv28.pdf
  19. #59
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    827
    I think all (or at least a high majority) of EFI systems use return-style fuel systems. My understanding is that helps maintain consistent fuel pressure all injectors and helps with hot starting.
  20. #60
    12,174
    Quote Originally Posted by CamTom12 View Post
    It is basically a purge line which minimizes the possibility of vapor build up in the system. Vapor in the system creates difficulty in starting due to the intermittent fuel/air flow at the nozzles. The slow turning engine can not maintain operation.
  21. #61
    3,891
    .... I am going to mount the battery in the boot cowl area similar to the Dakota Cub battery mount for super cubs. ....
    I know a couple guys with that setup in their cubs & I don't see any big advantage.
    With a cub, I think I'd put the battery under the front seat.
    With a 180/185, I'd put it on the firewall (engine side).
    If there's not much room up there, maybe put it under the one of the front seats?
    Pic is from a friend of mine, battery sez concorde but it looks smaller to me than a std 25 or 35 size.
    An Odyssey battery would fit nicely into this location.
Name:	underfloor battery.jpg
  22. #62
    Dec 2017
    NE
    81
    I apologize that my question may have been vague. I am looking at the EFII system because the fuel injection is simple, they build electronic ignition and incorporate a buss manager that will manage three batteries, a primary,a secondary and a backup. The fuel injection uses two electric pumps for fuel delivery. Fuel is pumped to the first injector then on down the line to each cylinder then to a pressure valve then to a return or the header tank. Mixture is controlled electronically and so is horsepower. I considered the header under extended baggage but the easiest route is no header with the return to the vent line, like suggested. More fuel could be in a belly pod or five gallon containers in extended baggage. Nearly all of my cross country will enable fuel stops with pit stops. The beer cracks me up and would only increase pit stops!
    The EFII fuel injection is wired so that if for some reason an injector is not firing the computer will try to fire it with another controller. However if a wire breaks I am sure that injector will not fire until the wiring is fixed. One positive in my book for EFII is there are no individual lines for the fuel to run out of or boil out because of heat. Hot starts ore not suppose to be an issue.
    My understanding is that fuel injected engines run higher compression for higher horsepower. The O520 I have for the build is carbureted, and I assume has lower compression pistons, that is something I will have to look into. Some will say why remove the carb and install FI, horsepower, no carb ice, efficiency, oh and horsepower.
    The boot cowl battery idea was to get it out of the heat of the engine, but you guys with firewall batteries can comment on that please. The battery under the seat in the Cessna looks pretty interesting.
  23. #63
    Mar 2010
    Southeast Michigan
    11
    What are the flap and aileron lengths? I think I have read 38' wingspan for the Cyclone's. The gap between flap leading edge and wing trailing edge, even with the flap closed is massive. Fowler gave us a wonderful achievement. The specified stall speed of 37 mph for this large/heavy of an airplane is great. It's a significant decrease from the certified spec. I really need to learn how to incorporate these control features into a wing myself.
  24. #64
    Dec 2017
    NE
    81
    The wings are a foot longer all at the root, so airleron is the same length as Cessna but the flap is a foot longer. If built with a wet wing you can get over a 100 gallon of fuel, I went with fiberglass tanks because I figured my wet wing would leak. If Patey would have built his wings for Scappy first I may have built wet wings similar to his.
  25. #65
    12,142
    In my experience with several airplanes with firewall mounted batteries is that heat on those batteries is a non issue. Shorter battery cables is a good thing, if for no other reason.
    Your work is impressive, I'm enjoying the show, thanks!
    Likes toklat$1, 180Marty liked this post
  26. #66
    Dec 2017
    NE
    81
    aktango, mvivion, anyone with info,
    I drug out the stol wing cuff that came with the kit and there is half a stol kit. Well 2/3, wing tips and the outer leading edge wing cuff, but not all the pieces to put on a full stol kit. Therefore I am going to try and built my own sportsman copy. The questions I have are what would be a suitable substrate to glue to the leading edge of my wings, balsa, closed cell insulation board, or any suggestions appreciated, to fill the gap between the wing and sportsman leading edge? I think I can bend the leading edges, I made a leading edge for one of the flaps. Which rivet to use? Avex, a cherry pull, something that the stem would stay in would be good. I figured I could cut up the tips I have and lay up with fiberglass to make them fit. The leading edge that came with the kit has a cuff and the sportsman looks to be flat on the bottom?
    Thank you in advance!
  27. #67
    Dec 2017
    NE
    81
ID:	61063Click image for larger version.
ID:	61064Click image for larger version.
ID:	61065Click image for larger version.
    Made hoses for the brakes and mounted the park brake under the floor board then ran tubing to the outside of fuselage, they exit just behind the landing gear. The next day I secured the brake tubing with Adele clamps.
  28. #68
    Dec 2017
    NE
    81
ID:	61067Click image for larger version.
ID:	61068Click image for larger version.
ID:	61069Click image for larger version.
    Built and installed this today. It is a control stop for the elevator, it is in the tunnel at the front of the cockpit. This one is the second I made, the first had a twist in it and I didnít like the way it looked, no one will ever see it! Slow progress my real job keeps taking me away from building. Had a fun time installing the screws and nuts to secure this part, need longer arms, smaller hands, or some help.
    Likes 180Marty, bcone1381, WWhunter liked this post
  29. #69
    Dec 2017
    NE
    81
    Ranching keeps getting in the way of airplane building!!! Working in the firewall, hung the engine mount and the heater valve, made some hose connectors and riveted them on the heat duct then riveted the heat duct and dog pan to the firewall. Seems like more tinkering that real progress.
  30. #70
    Dec 2017
    NE
    81
    I am wondering about checking the thrust line on this build. Where would one check the fuselage for level, top of door frame, floor?
  1. Super Cyclone?
    By glassjet in forum Cessna: C180/C182/C185
    Last Post: 02-21-2019, 09:42 AM
  2. Super Cyclone?
    By glassjet in forum Take Action Jackson
    Last Post: 02-16-2017, 12:50 PM
  3. super cyclone
    By supercyclone in forum Cessna: C180/C182/C185
    Last Post: 08-26-2015, 10:26 AM
  4. super cyclone
    By supercyclone in forum Cafe Supercub
