Results 1 to 34 of 34
Thread: Glide ratios in a Super Cub
    Mar 2019
    Anacortes, WA
    55
    Attached is an article I wrote for our local EAA chapter. I hope it can provide a practical tool to selecting an emergency field. While I developed the idea in my Cub, it can be used in pretty much any aircraft.
    Dan
    Thanks stknrddr thanked for this post
    Likes Kid Durango liked this post
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,106
    As one who has done a fair bit of dead stick ridge soaring, (in a RANS S-7S, not a SC) I'm going to hazard a guess: 7 to 1? Work calls, I'll read your article tonight.
    Likes mixer liked this post
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    674
    Quote Originally Posted by Dnh98221 View Post
    Makes my eyes and head hurt so I gave up trying to read it. How did you manage to make a PDF so fuzzy?
    gdafoe's Avatar
    924
    Oh wow, I really want to read it too. Is there a way you can send it or a link to it that works for my old eyes.?
    Gerald
    11,174
    I always was told radius below looking at horizontal jury strut brace was a quick guide
    Mar 2019
    Anacortes, WA
    55
    Ooh, sorry about the pdf. It looked good on my computer when I sent it. Let me see I I can fix it.
    May 2020
    8
    It's amazing how much drag a windmilling propeller creates. NACA did a test many years ago on a PA-18-95 using it in a glider configuration (propeller removed and the engine cowling opening all closed over) and recorded a 10:1 L/D or glide ratio.
    Likes mixer, jnorris liked this post
    12,058
    First, look right under you. THEN, if nothing there, look VERY close to the plane.
    Do you KNOW what the wind is at altitude? Do you know what the wind is on the surface?
    If you try to stretch a glide, either of those, and a dozen other variables can bite you.
    And, sometimes, the best solution is right under you.
    JP's Avatar
    Mar 2003
    The Big Woods of Maine
    3,325
    Simple. Jury strut on the side, and out the front that spot that isn't moving away or towards. That is as far as you will make it.
    JP Russell--The Cub Therapist
    1947 PA-11 Cub Special
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    418
    In my -12 it is the top of the cowl as I look out set for VY, I will hit that spot not above it but the spot or short.
    Easy way to see where you can go.
    Doug
    Thanks 62E thanked for this post
    May 2021
    Arizona, USA
    674
    Quote Originally Posted by JP View Post
    Perhaps important to distinguish between "as far as you will make it" and "as far as you can make it". At any speed and with any airmass motion there will be a spot that doesn't move. Doesn't mean that spot is a far as you could glide if you flew best glide speed for the conditions. POH best glide speed is for max gross, zero wind, and zero airmass vertical motion. These are not usually the conditions that exist when the engine stops.
    Nov 2019
    Kalispell, Montana
    55
    To confirm what MTV wrote: I took a Forest Service check ride out of Missoula 50 years ago. The inspector suddenly said “Engine failure!” I rolled the 206 sharply to the left. There was a strip right under me! End of emergency.
    Likes jnorris liked this post
    don
    785
    Most light planes we fly have a glide ratio around 7 to 1 + or- Boeing 747 ratio is 15 to 1 +.
    Nov 2019
    Kalispell, Montana
    55
    A friend of mine took a check ride in a 747 sim. They flew under the Golden Gate Bridge. He was admonished to fly very low: “Do you know how high your tail is!” Then the inspector pulled all four engines to idle. “What are you going to do now!” The plane had enough speed and glide ratio to return safely to SFO.
    Likes kestrel liked this post
    May 2021
    Arizona, USA
    674
    Quote Originally Posted by Farmer Hank View Post
    I knocked the tail off an MD-11 doing the same. (Lots of time in sim cabs doing engineering development and there was sometimes time to play)
    Thanks jayb thanked for this post
    Likes aktango58, jayb liked this post
    JP's Avatar
    Mar 2003
    3,325
    Perhaps important to distinguish between "as far as you will make it" and "as far as you can make it". ....... These are not usually the conditions that exist when the engine stops.
    All good considerations. This is as far as I could make it. Established best glide (55 for the 11) while picking best spot upwind and uphill within a 45 cone, and down we went. Right on the spot.
Name:	2021-10-11 12.52.18.jpg
    May 2021
    Arizona, USA
    674
    Right on the spot.
    It must be nice to have options like that. Where I fly in AZ a Cub is very seldom in glide range of a spot as nice as that. The places that the locals call airstrips aren't even as nice as that.
    Likes JP, Eddy Lewis liked this post
    12,058
    As suggested earlier, you MAY have to make a turn into the wind, once you get to your chosen landing site. A tailwind on landing off airport can cause a LOT of damage…..to the occupants. How far you can glide in a straight line is just one PART of an engine out emergency.
    Likes cubdriver2, 40m, hotrod180 liked this post
    JP's Avatar
    Mar 2003
    3,325
    For this practice session I was in luck; 5 minutes prior I was over the endless woods and headed towards even more, and had just left a small, tight strip on the edge of a lake with lots of lovely obstacles.
    AZ is stunning and I hope to get back at some point.
    21,812
    PDFs uploaded here get fuzzy for some reason. Might email it to SJ and see if he can post it.
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,106
    The S-7, with 29" tires, dead stick performance probably about the same as a SC. 1 notch of flaps, indicated speed about 55 mph I think. https://youtu.be/PkxFzQE2gEo
    On short final, it was looking about right to continue the dead stick to a landing, which I've threatened to do on my strip but haven't yet, I'll save it for when I need it. Plus I'm scared.
    May 2017
    1,373
    I've kept a PA-18A-150 up with the engine shut down (and tow rope) for over a half hour from 2000'. I even outclimbed one of the 2-33s that had a student in it. Supercubs glide pretty good considering.
    Likes courierguy, Delta Cub liked this post
    cubflier's Avatar
    Nov 2003
    1,414
    Flying over cold water that will kill you if you take a swim will cause you to set reasonable glide ratio expectations. I use 1 mile of glide per 1000 ft of altitude.
    Keeps the thought process simple. If I cross between two islands I try to cross at half the distance times 1000 ft. A 16 mile water crossing means cross at 8000 ft. It gives me time for all the stuff that will happen when the engine gets quiet.
    Jerry
    Likes DENNY, BC12D-4-85, Bill Rusk, Delta Cub liked this post
    3,875
    Quote Originally Posted by cubflier View Post
    Flying over cold water that will kill you if you take a swim will cause you to set reasonable glide ratio expectations. I use 1 mile of glide per 1000 ft of altitude. Keeps the thought process simple. ....
    Good thinking.
    Cessna indicates about an 8:1 glide ratio,
    so about 1.5 miles per 1000' of altitude.
    Of course, that's if you are right on the mark for the best glide speed *at your actual weight*,
    and doesn't account for time spent turning to a new course, stabilizing your airspeed, etc.
    So your 1 mile:1000' is probably a lot closer to reality.
    12,058
    Jerry
    You must be getting old like me Jerry! I can remember vividly many crossings of Shelikof Straight, wishing I could get a bit higher, like ten thousand feet higher….but I was young then, and perhaps not quite as…..er bright?
    Good advice, in any case.
    Likes cubflier liked this post
    jnorris's Avatar
    Wisconsin
    918
    This is sage advice. I've spent a fair amount of time flying high-drag aircraft, and have learned that the only place that you are absolutely, positively sure you can make is that which is directly below you, or nearly so. That's where I always start! If you have to start looking farther and farther away, your chance of success diminishes pretty quickly.
    Joe
    Fortis Fortuna Adiuvat
    Likes skywagon8a, supercrow liked this post
    Feb 2006
    Cortez Colorado
    121
    Some places there are no good options.
    7,821
    Where were you guys when the discussion was single engine along the coast from Seattle to Anchorage? That run scared me looking at it from a jet at 35,000 feet! Talk about cold water and no beach . . .
    Likes Bill Rusk, Eddy Lewis liked this post
    12,058
    There is a balance between stupid and trusting your engine. I had an engine failure in a very inhospitable place. I landed a place that was more hospitable, but I guarantee nobody here would land there intentionally. Pretty well used up the plane. That evening I went to dinner with Gina and relatives of hers she hadn’t seen for years. I’m sure they figure Gina married a wino.
    You just have to walk, or crawl away. You can get another plane. Land slow, and Use the plane up and it’ll likely save you.
    3,523
    Mike, didn't the plane do a full rollover coming to rest upright?
    12,058
    Gary,
    Yes, it tumbled. Toe of right float hit a tussock....big one. The area was the only one around not covered with trees, because it'd recently burned. But, as you know, all that country is tussocky.
    Likes 62E, BC12D-4-85 liked this post
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,562
    A very simple adage……just toss your car keys out…… That’s where you’re going to land. LOL
    Very Blessed. "It's not an obsession, it's a passion"
    Thanks wanna14 thanked for this post
    Likes jnorris, OzAK liked this post
    3,523
    Mike owes PK floats and Cessna for building durable stuff. Amazing.
    Likes DENNY liked this post
    12,058
    Never questioned that for one second. And happy to get right back in another.
    Likes Eddy Lewis liked this post
  1. Determining Best Glide Airspeed for Your Super Cub
    By WindOnHisNose in forum Cafe Supercub
    Last Post: 05-23-2021, 10:08 AM
  2. Gliding ratios
    By Samsam in forum Cafe Supercub
    Last Post: 05-22-2021, 05:34 PM
  3. Replies: 10
    Last Post: 11-02-2004, 01:02 AM
