Results 1 to 25 of 25
Thread: Labelling switches and breakers
    Jul 2010
    56
    Hi, everyone.
    I've got my panel powder coated, and it's time to label the switches and breakers.
    What do you you use over a powder coated surface? Do you use dry transfers + lacquer, silkscreen, an office label gun?
    Any advice would be appreciated,
    A.
    Likes silflexer liked this post
    stewartb's Avatar
    Wolf Lake, AK
    7,155
    Here’s what Mike used on mine. It holds up better than I expected and will be easy to change in the future if I choose to.
    https://decalprofx.com/
    Thanks tedwaltman1 thanked for this post
    Jul 2010
    56
    Nice panel. That looks great! Have you been flying the plane? Are there any signs of it peeling or rubbing off as you use the switches?
    stewartb's Avatar
    Wolf Lake, AK
    7,155
    It does wear if rubbed on, but otherwise it looks like it did 3 years ago when applied. I’ve heard of guys clear coating over it but know nothing about that.
    Thanks Andy505, RVBottomly thanked for this post
    7,821
    I have used decals, and am now using plain old India ink and Leroy templates. The secret is a light overcoat of rattle can clear, followed by multiple coats of Future Floor Wax applied with a Q-Tip.
    behindpropellers's Avatar
    NE Ohio
    7,037
    Quote Originally Posted by Andy505 View Post
    Hi, everyone.
    A.
    I laser etch the panels I make.
    Likes Broncoformudv liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    897
    That laser etching looks great! Is that on a powder coated panel or just regular paint?
    Apr 2008
    Michigan
    111
    I used the decal pro also. Over carbon fiber and clear coat over itClick image for larger version.
    Likes stewartb, tedwaltman1 liked this post
    4,459
    You can laser etch the powder coated panel. The trick, I was shown locally, is to put contact paper on first, then laser etch to the metal. If you leave the paper on it acts as a mask for any color paint that you want the labeling to be.
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    891
    http://www.aerographics.com/ Vinyl not dry transferClick image for larger version.
ID:	59176Click image for larger version.
ID:	59177Click image for larger version.
ID:	59175   Click image for larger version.
    Likes 40m, kestrel liked this post
    RaisedByWolves's Avatar
    Feb 2005
    4,690
    Quote Originally Posted by Bearhawk Builder View Post
    I do the same and a matte clear coat over it.
    21,812
    Ditto here.
    Jul 2010
    56
    That looks beautiful! Thank you for the suggestion.
    Was the matte clear coat sprayed on?
    3,875
    I don't have a fancy panel, so had no qualms about just using a simple electronic label maker.
    You can buy one for under $40, but a buddy of mine had one that I borrowed, so pretty much zero cost.
    You can make the labels black on white, black or white on clear, or whatever, using different tapes.
    I think they turned out pretty good.
Name:	placard - cabin air.jpg
    The C180 TCDS & an AD required an extensive placard on the panel, "in full view of the pilot".
    I experimented with my computer word processer & printer to get the required sized lettering,
    then printed it & attached it with clear packing tape.
    Again, not fancy, but good enough for my utility grade panel.
    And like the label-maker placards, easy to remove or replace later if required.
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    674
    I have used a similar technique, most recently for the ADS-B Out placard in my PA-28. I create the placard with a double line border, print on the laser printer, laminate between clear packing tape and double sided tape, then cut out and mount.
    Not as nice as laser cut but good enough to get the installation signed off and it's still there several years later.
    21,812
    Yes it is.
    May 2006
    Wasilla,Ak
    542
    Used a trophy business to engrave panel label and smaller labels. The small labels are attached with 3M double sided tape which also works well for the VG’s.
    Likes stewartb, Bill Rusk liked this post
    May 2006
    Wasilla,Ak
    542
    Use subpanel as drill guide for label material then off to the CNC to cut lettering.
    Likes Bill Rusk liked this post
    stewartb's Avatar
    Wolf Lake, AK
    7,155
    I like your overlay idea a lot. Thanks for sharing it.
    Thanks Litecub thanked for this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    897
    Not to be critical but what's the purpose of two panels stacked on top of one another? Just a color accent? All it's holding is a few breakers and switches...
    May 2006
    Wasilla,Ak
    542
    The sub panel is able to be removed with a service loop in the wiring which makes it much easier to work on the switches and avionics. There are 3 sub panels for this aircraft and I have nut plates on the back side of the structural panel for support. Hope that makes sense. Can put a picture up later if not clear.
    Sep 2014
    Fairvew East (Crane Road Airstrip),Wasilla, AK
    58
    Hello all,
    I succumbed to a lousy suggestion at the powder coat place when I made my panel and bought into a flat black "crinkle-coat" finish that has truly zero glare. It also has almost zero affinity for stick-on anything - thus several of the labels suggested here have not stayed on. The finish looks sort of cool but that is it's only benefit. With it already installed in my flying PA-14, the ability to etch or such things seems zero too. Any ideas in this setting?
    4,459
    Stick the placards on with clear RTV.
    Thanks salex thanked for this post
    stewartb's Avatar
    Wolf Lake, AK
    7,155
    Try 3M VHB tape. I keep a roll on hand since using it for VGs. It sticks to my powder coated panels just fine.
    Likes Litecub liked this post
    May 2006
    Wasilla,Ak
    542
    No need to get on your back and crawl under the panel to work on it with this setup.
    Likes DENNY, Steve Pierce, hotrod180, RVBottomly liked this post
  1. Panel wiring, circuits, breakers, switches, etc.
    By Helmetfire in forum Modifications
    Last Post: 10-24-2021, 11:51 PM
  2. Bus Bars and Circuit Breakers
    By KJC in forum Modifications
    Last Post: 08-23-2013, 09:31 AM
  3. Replies: 10
    Last Post: 01-30-2013, 08:47 PM
  4. breakers/buss bar
    By D.CUB NUT in forum Super Cub Sick Bay
    Last Post: 10-28-2003, 10:24 PM
