Results 1 to 15 of 15
Thread: Loctite 515 Only - Case Halves
    Grant's Avatar
    At Work.....
    1,974
    Planning to start assembly of my engine next week. It sounds like the current guidance from Lycoming is to use only Loctite 515 on the case halves and NOT to use silk thread. Anyone been brave enough to omit the silk? I used 515 and silk on the last one and its dry as a bone.
    Thoughts
    Valdez, Alaska
    697
    I omitted the silk and have one small leak…I would use the silk if I do another engine…
    RaisedByWolves's Avatar
    Feb 2005
    4,690
    I have heard it works good with the lycon o ring
    stewartb's Avatar
    Wolf Lake, AK
    7,155
    My 2019 factory new IO-390 has thread.
    Mar 2020
    32
    0-360, no thread, 600hrs + no leaks ….. if I did again, maybe I would use thread?
    12,000
    Use the thread. It doesn't weigh anything and the cost is nothing. Unless you want to take a chance that it won't leak?
    3,875
    Quote Originally Posted by Grant View Post
    .....I used 515 and silk on the last one and its dry as a bone.
    Why do it differently this time?
    "If it ain't broke, don't fix it".
    Likes tedwaltman1 liked this post
    Grant's Avatar
    At Work.....
    1,974
    I know - It's just that the current guidance is to omit the silk thread. I'm not sure I'm brave enough to use just the 515. Seems to me like it SHOULD work just fine without it but I KNOW it works just fine with it too!
    Thanks Fellas!
    Mar 2020
    32
    I guess it’s just following the manufacturers guidelines.
    I don’t think anyone is trying to ‘do it differently’, other than Lycoming changing their advice.
    stewartb's Avatar
    Wolf Lake, AK
    7,155
    When was this advice published?
    21,812
    What I read from Lycoming was that it was optional, silk thread and Aviation Permatex or Loctite 515. Have done both recently and in the past without issues on any.
    21,812
    How can you tell?
    Thanks flynlow thanked for this post
    Likes JeffP liked this post
    stewartb's Avatar
    Wolf Lake, AK
    7,155
    I changed the sump. It was obvious.
    21,812
    Yep, you can see the thread at the sump. Didn't know if they documented it on a work order or something. It was a Thunderbolt engine?
    stewartb's Avatar
    Wolf Lake, AK
    7,155
    Yes, Thunderbolt. I trimmed thread at the front of the case. Lycoming had placed their sump gasket over it.
    Likes astjp2 liked this post
  1. Replies: 15
    Last Post: 02-08-2016, 06:56 PM
  2. Sealing case halves
    By 16-bravo in forum Cafe Supercub
    Last Post: 04-04-2012, 02:56 PM
  3. Scott 3200 wheel halves
    By On Patrol in forum Cafe Supercub
    Last Post: 02-05-2010, 05:43 PM
