Gordon Misch
MEMBER
Well, once again soliciting wisdom - -
Together with a friend, I'm building an Experimental Amateur Built -12 knockoff, and the plan is to put it on amphibs. The question, re engine, is whether to go with the efficiency and intake icing resistance of Fuel Injection, or stick with a carb for reliable hot starting. The engine will probably be O-360 or something similar in that displacement range. Probably all electronic ignition, but possibly one magneto and one electronic.
We would very much appreciate thoughts and experiences from those of you with lots of time in each engine configuration, especially if on floats.
Thanks!
Thanks!
