New to us pa-12 and fuel system discrepancy between what we have and what the parts manual shows. I think the parts manual is in error. This is a 1946 pa-12 with header tank. Fuel panel placards say front valve is main tank shut off. Left tank. Must be on at all times in flight. Looking behind the panel shows the valve is just past the header tank in line to strainer. Same on parts diagram. Rear valve says , right aux tank on and off. And a visual shows it on the upper line as in parts diagram. But parts diagram shows that line goes to the left tank! Without taking interior and wing fairings apart I can’t trace were the lines actually go. Does anyone still have this old setup and know if rear valve is indeed on the right tank line?
