Thanks Thanks:  0
Likes Likes:  0
Results 1 to 3 of 3
Thread: Lycoming vacuum pump drive
    Nov 2015
    Fairbanks, AK
    128
    Hello all,
    Looking for a Lycoming vacuum pump drive adapter and gear assy, can be as removed, preferably low to mid time as it’s going on a low time IO-360. I’ve done the p/n research and Lycoming used this drive on a huge number of engines, O-320, IO-320, O-360, IO-360, etc on up to the 540s and probably the 720 as well.
    Hopefully someone out there has one they pulled off when they did away with their vac pump system and went to electronic instruments etc.
    Im installing a B&C direct drive alternator that mounts and is driven off the vac pump pad but the engine I got with my project has had that drive deleted.
    If it helps…P/Ns. Drive adapter assy- 61098
    Gear assy- 72970
    Thanks in advance for any help I can get on this.
    Mike Osborne
    OzAK
    Fairbanks AK
    21,783
    I have one Mike. steve@pierceaero.com
    Nov 2015
    Fairbanks, AK
    128
    Thanks to all that responded, PMs sent, problem solved. Gotta love this forum!
    Mike “Oz”
  1. FS: wet vacuum pump
    By hotrod180 in forum Parts and Pieces
    Last Post: 04-20-2018, 10:37 AM
  2. Vacuum Pump Pad
    By sburg58 in forum Cafe Supercub
    Last Post: 08-22-2013, 01:48 AM
  3. Vacuum pump
    By mongo in forum Experimental Cubs
    Last Post: 12-30-2010, 10:39 PM
