I'm in the market for some floats for an American Legend Texas sport. I'm wondering if regular PA11 or PA18 rigging will work?
The Texas sport is 3" wider so I wasn't sure? Any ideas what rigging will and will not work for my applications?
Basically the same except for the width. You may need to make extensions for the cross wire's wire pulls.
NX1PA
What skywagon8a said. Wipaire’s widebody and standard width Cub rigging is identical except for the wire pulls. Makes it easy to swap from one version to the other and keeps unique parts count down.
—Amy
Center of mass and gravity, deck angles, and uprights, diagonals, and flying wires, etc. would have to be checked. Call EDO or legend—they should know for sure because for sure is way better than a maybe and I hope so.
mixer liked this post
What you really should try to find is a set of Baumann 1500 or 1420’s.
That part I cannot answer, but EDO or whatever float manufacturer you are looking at may be able to help you out. I’m good for Wipline float questions but can’t speak with much authority on other models.
There is likely a lot of similarity but you’ll likely need to consult drawings to verify. Since the PA-18-95 had a higher gross weight, it may have some differences.
—Amy
Proud owner of a collection of airplane pieces (sometimes in one big piece) known as the Oklahoma Kid.
