krines
Billings
Was out flying yesterday which was a perfect day for carb icing. So I thought it would be good to check the carb inlet temps. During cruise it was 17F and with carb heat it was only 32F with OAT of 30F and the same at low rpm. Sutton exhaust with normal EGT on number 2 cylinder. O-320 b2b that we recently did a top overhaul with new Lycon port and polished cylinders. Prior to the top I would get carb inlet temps of 38F with OAT around 10-20F. Airbox etc. double checked and functioning well and properly installed. RPM drop about 50 with carb heat applied. How can I improve carb heat temp with the sutton exhaust or am I overthinking this and just fly. Steve
