Results 1 to 10 of 10
Thread: 1957 Cessna 180 A bottom door hinge
    Feb 2011
    S.E. MO.
    20
    I need a NOS or a very good used bottom door hinge for my 1957 Cessna 180. It’s the early flat steel version. Thanks for any help locating one.
    nd
    3,739
    Nov 2006
    84
    Take it to your local welding shop and tell them you need a new one for your boat. They will be identical except new
    21,502
    Do you have a part number?
    Feb 2011
    S.E. MO.
    20
    Cessna part no. 0411579-5 Hinge Assembly-Lower. Both left and right are the same.
    21,502
    Sorry, I have some 0711037-3 and -4.
    3,749
    Quote Originally Posted by 60CUB View Post
    Cessna part no. 0411579-5 Hinge Assembly-Lower. Both left and right are the same. Thanks
    Looking at the IPC now....
    page 107, LH door:
    hinge assembly 0411579-5 consists of
    0711037-3 hinge lower LH rear &
    0711037-10 hinge lower LH forward
    page 113, RH door:
    0711037-4 hinge lower RH rear &
    0711037-8 hinge lower RH forward.
    So a little inconsistency on the p/n's making up the "identical" 0411579-5 LH & RH hinge assemblies.
    Feb 2011
    S.E. MO.
    20
    Any idea why ? My serial number is 32801 and parts book calls for same assembly part number for both sides. I am rebuilding this plane and have all the hinges off . Both left and right bottom hinge assemblies are exactly the same.
    3,749
    Same assembly number RH & LH, but different sub-part numbers.
    But the different p/n LH & RH parts just might be identical--
    who knows what evil lurks in the heart of Cessna?
    Apr 2010
    Anchorage, AK
    13
    https://www.robairrepair.com
    Super guy. Quality stuff
  1. FS: Cessna Door Hinge 0711037-17
    By Grant in forum Parts and Pieces
    Last Post: 08-21-2021, 01:45 PM
  2. Whats a low time original 1957 cessna 180 worth?
    By lancef53 in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 05-19-2007, 08:34 PM
