Page 3 of 3 FirstFirst 123
Results 81 to 109 of 109
Thread: PA-11 rebuild
  1. #81
    4,539
    Make sure any wiring is installed BEFORE the fabric goes on!
  2. #82
    Apr 2006
    Aurora. Colorado
    47
    No wiring...too complicated for this bird.
    Likes wireweinie, Crash, Jr., KevinJ liked this post
  3. #83
    Apr 2006
    Aurora. Colorado
    47
ID:	59693Click image for larger version.
ID:	59694Click image for larger version.
ID:	59696Click image for larger version.
ID:	59697Click image for larger version.
ID:	59698Click image for larger version.
ID:	59699Click image for larger version.
    Photo dump with some progress. Both wings are ready for cover with all new perimeter, new ailerons, and new pulleys from Dakota cub. Useless trivia...an uncovered wing/aileron assembly with no fuel tank is 62.5#. I'll try to get a number after cover and paint.
    We checked them on the fuselage one more time to make sure they still fit. Everything looks good.
    Polyurethane on the floor boards.
    Now on to covering. Spent a bunch on covering stuff and even found some MEK in Colorado. Time to start wrapping!
    I picked up some parking brake valves because I think I'd use those. Hope to get the wings wrapped up in the next month. Heading to PHx this week to pick up a stab and set of elevators. Halfway hunting for gear legs if anyone knows of a set.
    Likes gisli liked this post
  4. #84
    11,263
    Buy new gear legs, after all your work you'll sleep better
  5. #85
    Apr 2006
    Aurora. Colorado
    47
    You're probably right.....I'm beginning to lean this way.
  6. #86
    supercrow's Avatar
    Dec 2008
    621
    If you decide to go with used there are several pairs here. Some with hydrasorbs and some without. PM me if you want more info.
  7. #87
    Apr 2006
    Aurora. Colorado
    47
    I've been NORDO for a while but this is moving forward. Both wings are covered as well as the tail feathers and gear legs. I ended up getting new legs from Univair.
    The fuselage has the super cub trim system installed and the super cub front seat belts, both using FA Dodge STC's. It is also primed with EP420. Covering will happen in the next week or so. Chasing down a few things I need to install before gets covered.
    I also need a cabane and shock struts. Anyone have a line on those? I was thinking standard bungees. Is there any reason I want or don't want hydrasorbs?
    I'll post some pics when I get a minute to dig through them.
  8. #88
    Aug 2012
    Kansas City
    29
    Looks like you have been putting Walt to work
  9. #89
    Apr 2006
    Aurora. Colorado
    47
    Quote Originally Posted by nbills77 View Post
    Those boys have been HUSTLING!!!
  10. #90
    May 2007
    10
    Pa-11
    This is going to be a great flying airplane!
  11. #91
    Apr 2006
    Aurora. Colorado
    47
    Is the PA-11 fuel tank the same as the LH tank from a PA-18?
    Dakota cub advertises a tank that fits both, but the filler neck may not be located in the same place.
  12. #92
    21,957
    The filler neck on original PA11 and PA16 tanks were not in the middle like the later PA18, 20 and 22.
  13. #93
    3,691
    The PA-11 left fuel tank was listed at 17 gallons @ +24 in TCDS A-691
  14. #94
    Apr 2006
    Aurora. Colorado
    47
    So the 18 tank will fit the 11 wing, but will require a different cover?
  15. #95
    21,957
    Correct.
  16. #96
    Apr 2006
    Aurora. Colorado
    47
    Does a PA-18 front seat bolt in to an -11?
  17. #97
    3,691
    Contact Atlee Dodge> https://fadodge.com and ask about SA462AL installation of PA-18 front seat in a PA-11
  18. #98
    11,263
    Quote Originally Posted by YJLopes View Post
    No, needs to be modified, Javron could probably make you one
  19. #99
    21,957
    I remember bolting one right onto a PA11. Don't expect to have a seat built at Javron and bring it to me for an annual on a certified PA11. Glenn can sign it off
  20. #100
    kase's Avatar
    Feb 2002
    Billings MT
    1,614
    Direct bolt in replacement.
  21. #101
    11,263
    Quote Originally Posted by kase View Post
    Not in mine? Was built in April of 47, maybe later ones. We took a Smith cub seat and had to build new legs
  22. #102
    11,263
    I don't blame you. But 99% of IAs wouldn't have a clue
  23. #103
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    1,026
  24. #104
    Apr 2006
    Aurora. Colorado
    47
    Seems a bit dramatic for something that is STC'd. I'll give Atlee and call and see if they still support it.
    Likes mixer liked this post
  25. #105
    11,263
    It's been almost 20 years ago we did this. We rebuilt the seat legs, but now I'm thinking we did that to make the seat the same height as the original 11 seat because the 18 one was too high?
  26. #106
    3,691
    My PA-11 factory seat was too low for extended flight. Like sitting in a bucket with knees raised above hips. I added a 4" flotation cushion for float flying. A PA-18 seat would have been more comfortable despite the spar carry through ahead.
  27. #107
    12,149
    My 11 had a PA-18 seat installed. I'm 5' 8", and the height of that seat put my head up close to the spar carry through. Still a lot more comfortable than the original front seat in 11s.
    If I were doing a fairly serious rebuild on an 11, I'd consider converting to the PA 18 top deck, and 18 spars. Gets that headache rack out of the way. But, not a small project.
  28. #108
    3,691
    It's unfortunate that some enterprising DER or equivalent hasn't analyzed the PA-11 and designed a 100# GW upgrade. More robust gear hardware, wing or strut mods, and fuselage ads as required.
  29. #109
    May 2007
    10
    PA-11 Higher Gross Weight
    Piper Aircraft did that back in 1949 when it came up with the PA-18-95 at 1500 pounds gross weight. The PA-11 was an honest effort to extend the life of the venerable J-3.
  1. My cub rebuild...
    By WanaBNACub in forum Member Projects in Progress
    Last Post: 11-12-2017, 09:09 PM
  2. PA-18-1 rebuild
    By JPachl in forum Cafe Supercub
    Last Post: 07-20-2012, 08:55 PM
  3. 337's for PA-12 Rebuild
    By Utah 12 Driver in forum Member to Member
    Last Post: 02-07-2010, 01:57 PM
