Results 1 to 5 of 5
Thread: Best prop pitch for C85 with stroker
    Jan 2013
    Hudson, MA
    103
    Wondering about prop recommendations for a C85 Stroker. The existing prop is a 74-46 Sensenich. Would it be worth re-pitching?
    3,201
    Depends. What's your static rpm noted by an accurate device? Is it within the airframe manufacturer's limits? What's the inflight maximum rpm again observed with an accurate tach? I prefer a Sen 76AK-2-40 to 42 for my Taylorcraft C85 Stroker (it's now at 40 from a previous 42). It will turn about 2600 in flight slightly over redline but that's controllable.
    Likes mixer liked this post
    soyAnarchisto's Avatar
    Aug 2012
    Boulder, CO
    620
    all of it - you want to make maximum static rpm according to the TCDS limitations and be able to achieve redline on climb out. The metal sensenich is the best one for the C-85 on the J3 anyway. You didn't say what airframe - read your type cert to see what your limitations and prop options are - then talk to your prop shop if you aren't making what you paid for.
    10,948
    An AK 76-2 is 74" and pitched to a 40 works well
    7,678
    Sea level guy here - I just use a wood 72/42, and get delightful performance. When I want to see 1300 fpm, I get the Super Decathlon out for a spin.
  1. WTB: Prop for J-3 C-85 Stroker
    By wrightmij3 in forum Parts and Pieces
    Last Post: 09-08-2021, 09:25 AM
  2. Cruise prop and climb prop pitch for C90-12
    By Andy Meyer in forum Cafe Supercub
    Last Post: 06-16-2021, 07:01 AM
  3. pitch of prop
    By RAC cubs in forum Cafe Supercub
    Last Post: 05-11-2014, 07:59 PM
  4. C-85 Don's stroker mod. Need advice on prop
    By RobL in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 02-26-2009, 03:50 PM
