Results 1 to 34 of 34
Thread: Help: J3 w&b / wing loading profile
    Nov 2021
    6
    Hey forum,
    Im newer to the cub world and been flying a lovely j3, however I want to be certain about my W&B and wing loading which I can't seem to nail down in Forelights W&B (fwd/aft cg locations). If anyone is extremely well experienced on W&B and figuring out FWD vs AFT cg on the wing I would greatly appreciate it. Ive included the W&B sheet, sad to say its a bit confusing to me and there's not a lot of helpful detail on the web.
    My other question is given the max wt of these planes how does anyone go about flying two adults and decent amount of fuel, especially if you add floats?
    7,635
    When they weigh 835# empty, they become officially one place aircraft. You have a useful load of 385 lbs - enough for two 170 lb adults and 45 lbs fuel - or, if you are like most of us, two 190 lb pilots and 5 lbs fuel.
    It seems like almost all J3s wind up that way when you weigh them. I have no idea why. It is legal (although it seems to horrify most folks) to compute your weight and balance using factory original weight. Be very careful - there are two data - use only one of them. Easiest seems to be wing leading edge. The datum 46" ahead of that was because the factory wasn't sure mechanics understood negative numbers.
    2,512
    " My other question is given the max wt of these planes how does anyone go about flying two adults and decent amount of fuel, especially if you add floats? "
    Cold and windy out so I will start $hit storm early. The answer is simple they fly overweight. Happens a lot in small aircraft especially in small training aircraft.
    Nov 2021
    6
    Ya i figured, considering this holds 24gal of fuel its definitely a one place aircraft. I just don't understand how some of the local schools with j3's on o-200s and floats can even teach dual. Is it normal for people to run these overweight and safely? How far out of CG does it get?
    Foreflight asks for the FWD most points of CG and AFT most points - there should be two to three for the front and two for the back of the envelope, however piper never supplied wing loading graphs so im unsure how I find them with the included W&B
    Nov 2021
    6
    it seems that would be the only way, i guess i want to figure out with the W&B how far out of FWD/AFT cg it gets
    1,166
    Forward limit is 10.6, aft limit is 22.7 per the Type Certificate Data Sheet.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    746
    There's a really nice weight and balance spreadsheet available from the J3 cub forum. I'll put a link to a google drive copy of it.
    https://docs.google.com/spreadsheets...f=true&sd=true
    There's a few things you can lose to save weight including the starter, battery, and going with a 4 quart oil sump instead of 6 depending on what engine is installed. Regardless, it's going to be on the heavier end of what J3's weigh at but if it flies good that's all that matters.
    Nov 2021
    6
    looking at the W&B sheet I provided, does that then mean 10.6 aft of WLE (which WLE is 48.5") so 59.1?
    also what weights would I be looking at for FWD/AFT CG ranges - I assume empty weight and then max gross but there has to be a limit to FWD CG weight since you dont fly from the front
    Just trying to get the ranges Click image for larger version.
Name:	Foreflight WB youtube pic.jpg
    1,166
    Quote Originally Posted by CaptnNick View Post
    I didn't look at the W&B sheet you had, but it all depends on the datum used. The TCDS uses the wing leading edge as the datum.
    3,100
    ... I just don't understand how some of the local schools with j3's on o-200s and floats can even teach dual. Is it normal for people to run these overweight and safely? How far out of CG does it get?...
    Contact Jack Brown's Seaplane Base and ask about their J-3's on Aqua 1500 W&B?
    7,635
    Doesn't the gross weight go up a bit on floats? And I bet Jack won't let those Cubs get anywhere near a scale.
    1160 lb. with McKinley floats
    1200 lb. with Edo, Wollam or Heath floats
    1300 lb. with Edo 60-1320, Edo 92-1400 or Wollam 1200 floats
    Jan 2016
    64
    3,100
    See Page 24: https://www.flymall.org/docs/Seaplan...laneManual.pdf Things weigh less near the Equator.
    But wait there's more> https://www.aviationconsumer.com/saf...owns-approach/ Notes here 1420# GW so must be via Aqua's STC?
    Jan 2016
    55
    697 Pounds empty? Wow, that's a very light J-3. Wood prop, lite fabric and minimum coats dope/paint?
    7,635
    Mine rolled out with metal spar wings at 718 lbs. in June 1946.
    We pretty much determined that wood spar wings are lighter - we decided on 8 lbs per set after several weighing exercises. Earlier Cubs often show factory weights in the 690 range. Lighter landing gear, lighter struts, maybe lighter bungees - who knows.
    In the olden days, Ray Stits told us his fabric saved weight. I think if you took all the fabric and paint off a J3 it would be between 40 and 80 lbs, no matter what process (except maybe Oratex). So where does that extra 100 lbs come from? I have no idea. Even a C-85 with starter and metal prop and wing tank only adds 50.
    Likes AKjurnees liked this post
    3,693
    ....Foreflight asks for the FWD most points of CG and AFT most points - there should be two to three for the front and two for the back of the envelope, however piper never supplied wing loading graphs so im unsure how I find them with the included W&B
    My suggestion is to throw out ForeFlight (at least for now) and read the W&B stuff on the J3C TCDS.
    It should answer your questions re fwd & aft CG limits, etc.
    Microsoft Word - A-691 Rev 34.doc (faa.gov)
    If you can do basic arithmetic, it's easy to do W&B calc's the old school way--
    weight times arm = moment, moment / weight = CG.
    For me anyways, it's easier that way to understand what's going on & why, vs using a whizbang app.
    Likes dgapilot, bob turner, Brandsman liked this post
    1,166
    There is only one forward point for the J3, I gave you that in a prior post.
    Your confusion is all based on the datum being used. The TCDS uses the wing leading edge. Everything aft of the LE has a positive arm, everything forward has a negative arm.
    The W&B form you posted in the opening uses a datum 48” forward of the leading edge will all arms positive. It doesn’t matter which method you use, you just need to use the same datum for all calculations.
    Likes bob turner, hotrod180, Southern Aero liked this post
    3,693
    Those "point in space" datums are a PITA,
    I think the Luscombe does that also.
    Dunno if they mix-n-match point-in-space and WLE like Piper does though.
    I like the firewall datum used on most Cessnas,
    much easier to measure a station, and to deal with in general--
    as long as you remember that a positive x a negative = a negative.
    1,166
    I think they used datums ahead of the airplane so it was all positive numbers. I never had any issues multiplying positive and negative numbers together, it's like 7th grade math.
    7,635
    Both of the above posts are on point.
    Avoid like the plague complicated spread sheets. They obscure what is going on.
    You may choose any datum you want, but if you know how to manipulate negative numbers the LE is simplest. I am currently using 46" ahead of LE, for no reason other than that is where I started.
    My buddy presented me with a complicated eight column spreadsheet on his J3. I am not dumb - although I am incapable of really simple calculations like subtraction, I am a whiz at vector calculus and integral transforms, and I found it incomprehensible.
    Do it this way - Weight x Arm = Moment. Start with factory numbers. Use the same datum for each addition or subtraction. At the end, add all the weights, being careful with plus and minus signs. Add all the moments. Then divide the total moment by the total weight. That gives you empty CG. If it falls within the TC specs, you are done.
    Then do a couple sample loadings - oil, fuel, one or two pilots, baggage - print them out and stick in an envelope. Present to the feds if you are ever ramp checked.
    Make sure you have a good chance to prove you are not overweight on paper. If you really, really need to know how much the aircraft weighs, then weigh it, but avoid putting that number on a 337.
    all opinion. Locally there is a 160 Super Cub with a 400# useful load, noted on a 337. A single place Super Cub!
    Likes DENNY, Crash, Jr. liked this post
    May 2021
    Arizona, USA
    308
    I created weight and balance spreadsheets for my racing sailplane (variable wing and tail water ballast) and for my FX-3. I have found both to be very useful. Nothing obscure but they do require careful verification. My first draft FX-3 attempt had a data entry error for the fuel arm.
    How many people who run close to the CG limits run the calculations for max and min fuel load? I do, and it's plotted graphically. A graphic weight and balance depiction is also given by the Garmin G3X system but, like the spreadsheet, it requires the entered data to be correct.
    Data entry errors are as much a risk in a manual calculation as they are in a spreadsheet. Excel is quite capable of error free multiplication and division.
    Likes mixer liked this post
    1,166
    When I flew a King Air, I even did the loading with gear retracted and gear extended. Pretty easy to get out of the envelope when you have a long fuselage!
    7,635
    As a BAC 111 first officer, I was responsible for a horrible run-around chart for wt/bal before each departure. So I wrote a computer program (in Basic) - it would ask for fuel, baggage fore and aft, and passengers, and spit out gross weight, I think CG, and V-speeds.
    Did the same thing for the 737.
    Then the airlines got smart and put a program in the big computer for the qualified gate agent.
    Even with such relatively complex computations, eight columns of data were not required. All you need is weight and arm.
    3,100
    Then they did this,
    On Board Aircraft Weighing System
    Some large transport airplanes have an on board aircraft weighing system (OBAWS) that, when the aircraft is on the ground, gives the flightcrew a continuous indication of the aircraft total weight and the location of the CG in % MAC.
    The system consists of strain-sensing transducers in each main wheel and nose wheel axle, a weight and balance computer, and indicators that show the gross weight, the CG location in percent of MAC, and an indicator of the ground attitude of the aircraft.
    The strain sensors measure the amount each axle deflects and sends this data into the computer, where signals from all of the transducers and the ground attitude sensor are integrated. The results are displayed on the indicators for the flightcrew.
    Likes jrussl liked this post
    RVBottomly's Avatar
    Sep 2017
    1,252
    Then they did this,
    I thought they had something like that. That's why the 737 tipping on its tail at Lewiston ID seemed so strange.
    https://www.news18.com/news/auto/uni...t-4223750.html
    7,635
    Makes sense. In the olden days it was an estimate, based on random loading and 170 lbs average.
    But note - the most sphisticated system does not give you an eight column spread sheet. Just weight and CG. All you need.
    Jan 2016
    64
    Right on all accounts regarding the long spreadsheet. However FF allows me to keep multiple aircraft W&B on file within fingertips on my iPad or in this case, on my phone. Any rampcheck I have it on my phone as current as it’s going to be. Forgot my phone you ask? Rarely, but I do have a paper one stashed behind my aircraft flight log folder.
    May 2021
    Arizona, USA
    308
    I like to see how you make a working weight and balance spreadsheet with only two columns.
    You only have mass and CG. Where does the arm go? Where does the description of the line item go (empty, fuel, front seat, back seat, baggage, etc,)
    7,635
    You don't. But you do not need eight columns, and the answer is only two numbers. If you have to print out things like flight number and number of passengers, destination, fuel load, etc, you may need some format other than gross weight and CG.
    What I saw was an eight column spread sheet for a J3. Serious overkill. Next time I open the big computer I will print my simplified version here.
    Simplified version (I cannot get tabs or spaces to reproduce here - but there are three distinct columns in the original):
    Empty weight 743.8 lb Empty C/G 61.5” Moment 45750.41
    Note that the new datum is 46” ahead of wing LE. This aircraft left the factory at 711 lbs @ 15.94” No significant changes have been made to the airframe since then, with the exception of the above equipment list.
    Sample Loading – Full Fuel
    Aircraft EW – 743.8 lbs 61.5” 45750.41
    Oil – 4 qt 8 17 136
    Fuel – 12 gal 72 (main tank) 28 2016
    Fuel – 6 gal 36 (wing tank) 70 2520
    Front seat 195 55 10725
    Rear seat 0 82 0
    Baggage 0 95
    Total 1054.6 lb 58 ” 61147
    Approved: 1220 lb 56.6” to 68.7”
    If empty C/G is aft of 59.8”, any load will fall within allowable range, including front seat solo. No placard is required on this aircraft.
    Nov 2021
    6
    intresting
    11,741
    That MAY work, right up till it doesn’t. I could introduce you to a well known, long time CFI/DPE who lost all their certificates for conducting a check ride in a Cub that was clearly in excess of legal GW.
    And that’s the problem: A CFI or DPE puts their signature in the students logbook, or in the FAA’s IACRA system…..which is no longer in the CFI’s control. If ANYthing draws the FAA’s attention to that pilot…..all is fair game.
    In a training environment, the CFI may or may not have control over who the DPE is. When I was doing SES ratings, both the DPEs in that district insisted on demonstrated legal W/B. It’s one of the reasons I sold my SC and bought a C-170.
    And, if you’ve ever met Brown’s Examiner, you’d roll your eyes even more. I think
    Jon has sold the business now, however.
    7,635
    The real problem is insurance. Losing all your certificates is painful, having your insurer say "we're outta here - you were intentionally flying in an unairworthy condition" can be catastrophic.
    While Mike is surely correct about that DPE, I suspect they were looking really hard st him for some reason or another. We pay serious attention to W/B at checkride time, especially the 709 kind, and so far the examiners just climb in and go around the pattern. It is almost as if they "know" but don't want to officially know.
    3,100
    If I had a J-3 or PA-11 I'd check wi†h Aqua floats to see if there's a GW up with their 1500's. Same with Baumann 1420 or 1500's for that matter. It would be worth knowing if it applies and to what models/SN's.
    Nov 2021
    6
    i think TCDS list a GW increase to 1300 for Aqua (not the 1400 or 1500 they claim over in JB's)
  1. Replies: 4
    Last Post: 07-13-2016, 06:52 PM
  2. Help loading photos please
    By T. van Vuuren in forum Experimental Cubs
    Last Post: 01-03-2010, 10:33 AM
  3. muzzle loading
    By Dave Calkins in forum Sportsman's Den
    Last Post: 12-07-2005, 06:47 PM
Tags for this Thread
