Results 1 to 17 of 17
Thread: B&C Starter Slow at first
    ATP, CFII, A&P sdischer's Avatar
    Dec 2019
    COLLEGE STATION, TX
    144
    I recently installed a B&C starter on my C90. Warm starts are normal but when the engine is cold (even “summer cold” not like middle of winter cold) when you press start, it barely has enough torque to turn through the first blade and often stalls there. If you let go of the button and press again it cranks through the same cylinder’s compression stroke and starts normal. I have even replaced the battery (because I switched to the Hawker battery) and even fully charged I still get the same result. Is the starter defective or is this normal? My old pull starter had way more torque. I emailed B&C but they didn’t respond. I guess I will try calling them.
    4,142
    You have a bad connection on the 'big' cables. Check each connection (ground and positive) for proper crimp, corrosion and clean, metal to metal contact. Another trick is to connect the battery ground cable directly to the crank case and a smaller braided ground from the crank case to the airframe. Never trust the braided ground soldered to some of the engine mounts.
    Thanks Hardtailjohn thanked for this post
    Likes astjp2 liked this post
    Dec 2019
    COLLEGE STATION, TX
    144
    Good ideas thank you!
    Dec 2019
    COLLEGE STATION, TX
    144
    Web, There is a single braided ground wire from the engine mount to the accessory case. That’s it. The battery negative goes to the frame at the battery. The engine mount is not bonded to the frame either. Is all that original or did someone miss some bonding when it was rebuilt last time? Seems to me like more bonding is needed.
    4,142
    Quote Originally Posted by sdischer View Post
    Where is your battery mounted? If it's on the firewall, moving the ground strap to the crank case is easy. If the battery is somewhere else, I like to ground the crank case to one of the screws that are welded to the airframe and stick through the firewall. Also, if your battery is mounted aft of the firewall, make sure that the ground strap connects directly to the airframe and not through a joint like the bolt on the seat leg.
    The braid on the engine mount doesn't work well because the engine mount is usually painted/powder coated, so the ground path has to get past that and then the bolts and hinges to get to the airframe.
    Thanks sdischer thanked for this post
    Dec 2019
    COLLEGE STATION, TX
    144
    Battery is in the aft position behind the passenger. I am going to dig into this tomorrow and get it corrected. Thanks for all your help.
    21,305
    I would put a volt meter on the starter connection to start and see what kind of voltage drop you have. Feel the braided ground cable at the engine mount to see if it is warm or hook jumper cable between the engine and engine mount and then try battery to fuselage if bad ground is suspect.
    Dec 2019
    COLLEGE STATION, TX
    144
    Thanks. What I gather is that the B&C should spin this little engine just fine unless it isn’t getting enough amps!
    Likes mixer liked this post
    3,695
    I had a similar issue with my 180.
    Fresh firewall mounted Odyssey, heavy Energizer starter that checked out good at the local auto electric shop.
    It hesitated getting past the first blade when cold.
    Pulling it through a few blades during pre-flight pretty much solved the issue, but I wasn't happy.
    I added a heavy engine ground cable from starter stud to firewall-- didn't do too much.
    I suspected a funky starter solenoid & just a couple weeks ago swapped that out for a known good one, that helped some.
    I then replaced the elderly solenoid-to-starter cable with new, it cranks perfectly now.
    I guess my point is that it sometimes isn't just one thing, it's a combination of things.
    One thing that can make a big cumulative difference is to disassemble & clean ALL the electrical connections
    all the way from the battery to the starter, and all the grounds.
    And make sure you have a good solid engine ground.
    Likes astjp2, Geffert, BC12D-4-85 liked this post
    Dec 2019
    COLLEGE STATION, TX
    144
    Web was correct. The strap from the mount to the case was there but really crusty looking. Upon removal and closer examination it clearly had been heated up. I sanded the pad it attached to, made a new ground strap, and added a #8 wire to the firewall. She spins as she should now. Thanks all.
    Thanks wireweinie, Steve Pierce thanked for this post
    Likes Steve Pierce, BC12D-4-85, silflexer liked this post
    Dec 2019
    COLLEGE STATION, TX
    144
    PS: Before anyone comments on those crusty engine mount rubbers, they aren't even a year old! Genuine TCM parts and still garbage rubber.
    Thanks wireweinie, Steve Pierce, AkPA/18 thanked for this post
    Likes Steve Pierce, Sam D liked this post
    4,142
    Put a dab of ACF-50 or similar on the ground hardware to help keep the corrosion from getting a start.
    Likes Geffert, AkPA/18 liked this post
    Dec 2019
    COLLEGE STATION, TX
    144
    Will do!
    Apr 2018
    33
    My uncle and I will be dealing with the wire corrosion on the 180 project after finished installing the new wheels, tire mounting and balancing on the current truck project. Gonna try that ACF-50 which also recommended by a friend mechanic.
    4,142
    Quote Originally Posted by Geffert View Post
    I've had good luck with it when assembling connectors for aircraft exposed to water/salt water. I'll dip the stripped end of the wire into ACF-50 before crimping the terminal onto the conductor. Then touch the end of the pin or socket to the ACF-50 before inserting them into the connector assembly. Between that and the weather seal on the connector, it seems to do a reasonable job in slowing corrosion.
    Likes jrussl, AkPA/18, Geffert liked this post
    3,695
    My uncle and I will be dealing with the wire corrosion on the 180 project .....
    I always enjoy looking at skywagons, maybe you can start a thread & post some pics of your progress.
    FWIW there's a lot of skywagon owners on this site -- some own one in addition to a cub, some not.
    Likes Geffert liked this post
    Apr 2018
    33
    I will, sir!
  1. Slow starter when hot
    By Charlie Longley in forum All Things Electrical
    Last Post: 07-11-2019, 02:30 PM
  2. Slow Flight is No Longer Slow... At Least for Those Learning to Fly!
    By SJ in forum The Art and Science of Flying
    Last Post: 09-11-2016, 12:51 PM
  3. Cubs are easy to slow down...... from going slow
    By HydroCub in forum Cafe Supercub
    Last Post: 06-12-2009, 10:21 PM
  4. Low and Slow
    By scout88305 in forum Cafe Supercub
    Last Post: 10-17-2006, 07:57 AM
